Distributor help
Old Mar 7, 2003 | 07:42 PM
Mr.Integra's Avatar
Default Distributor help
first i had to drill off the damn rotor screw and got shards everywehre. Cleaned it up.
Then i accidentally installed the distributor 180 degrees off and tried to start motor
Now that i installed it correctly, motor starts up fine. But runs VERY weak.
Any got any ideas? did my distributor go bad?
Old Mar 7, 2003 | 07:45 PM
Dan GSR's Avatar
Default Re: Distributor help (Mr.Integra)
how's your ignition timing?
did u check that?
if its retarded, you may loose some power
Old Mar 7, 2003 | 08:18 PM
Mr.Integra's Avatar
Default Re: Distributor help (Dan GSR)
i didn't use a timing light gun to check it. however i did check the mark on the distributor and it is aligned (which means 16 degrees)
95civhb
Aug 14, 2010 06:51 AM
azzurribaggio
Jun 26, 2009 09:25 PM
azzurribaggio
Jun 26, 2009 05:07 PM
MOVE OVER
Apr 11, 2007 07:11 AM
90_crx_si
Mar 23, 2004 03:58 PM
