Adjusting distributor timing
Old Jun 26, 2009 | 01:38 PM
azzurribaggio's Avatar
Default Adjusting distributor timing
So the other day I took my distributor off to check my ignition coil inside....never made it that far since I couldn't get the stupid rotor off due the screw looking kinda stripped. So I figured I'd scuff up the cap and rotor contact points a bit while they were accessible with some sandpaper. Well I never made a mark as to how the distributor was lined up and so now I think my timing is off. I actually put the distributor back in the wrong way since it wouldn't start for a while and I figured I was not at #1 cylinder at DTC. So I put it back in correctly but now it's starting albeit running super rough and eventually dies. In order to check the timing I need the car to idle on it's own, so do I rotate the distributor clockwise (if facing it from the passenger front fender), I assume advancing the timing, to where there is a gap to the right of the top washer/bolt assembly??? See pic: http://photos.e46fanatics.com/data/500/IMG_6198.jpg
HELP!
Old Jun 26, 2009 | 03:21 PM
slaminsam's Avatar
Default Re: Adjusting distributor timing
counter clockwise.
Old Jun 26, 2009 | 05:07 PM
94 ls-r's Avatar
If you put it in the center it is usually close enough to get it to run. Than make adjustments from there.
MastaFlyMason
Oct 2, 2016 02:53 PM
honda_crv_2000
Honda CR-V & Element
Jan 16, 2015 01:14 PM
95civhb
Aug 14, 2010 06:51 AM
96a-ccord
Feb 26, 2010 02:04 PM
azzurribaggio
Jun 26, 2009 09:25 PM
