Compression Test ?
C-Speed says nothing about cutting off elec. to the distributor. Is this neccesary? Also, can't I just unclip the two gray clips attached to the dist. instead of dicking around w/ the coil? TIA
Ryan, who appreciates C Speeds How to's, although wish they were a bit more descriptive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost Type R »</TD></TR><TR><TD CLASS="quote">Just pull the ECU fuse and crank away.</TD></TR></TABLE>
Where is this fuse located, I don't have a cover on my fuse box? Anyone? TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">i removed the fuse that cuts FUEL, not ecu.. as shown below
http://www.c-speedracing.com/h...t.php
Yes, but you can fry your coil if you don't cut power to the distributor also. Everybody has their own opinion on how to go about this.
</TD></TR></TABLE>Yes, but you can fry your coil if you don't cut power to the distributor also. Everybody has their own opinion on how to go about this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwitr »</TD></TR><TR><TD CLASS="quote">
let us know the #s when you get done</TD></TR></TABLE>
Will do, hoping this misshift hasn't caused any bent valves
let us know the #s when you get done</TD></TR></TABLE>Will do, hoping this misshift hasn't caused any bent valves
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost Type R »</TD></TR><TR><TD CLASS="quote">Another way is to just pull the injector clips off. The whole point is not flood your car with fuel while you're cranking it.</TD></TR></TABLE>
ditto.. i just pulled the injector wires off too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 »</TD></TR><TR><TD CLASS="quote">
Do you notice a bumpy idle? Give us your numbers
</TD></TR></TABLE>Do you notice a bumpy idle? Give us your numbers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost Type R »</TD></TR><TR><TD CLASS="quote">Do you notice a bumpy idle? Give us your numbers
What do you mean by bumpy? It seems a little rough although it idles exactly where it should around 800 w/o lights 1100 w/ lights.
</TD></TR></TABLE>What do you mean by bumpy? It seems a little rough although it idles exactly where it should around 800 w/o lights 1100 w/ lights.
bumpy as in abnormal idle issues... If it idles normally around 800 then you should be fine. But to play on the safe side about misshifting, i'd still recommend that you get compression numbers first and we can help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost Type R »</TD></TR><TR><TD CLASS="quote">bumpy as in abnormal idle issues... If it idles normally around 800 then you should be fine. But to play on the safe side about misshifting, i'd still recommend that you get compression numbers first and we can help.</TD></TR></TABLE>
Thanks, all the help is appreciated. I'm very confident the comp. test results will be normal, the car never went above 9,000 rpms and it seems to be running fine. I'm waiting to do the compression test as I just ordered some fresh NGK's and want to install them at the same time.
BlueShadow
25
Jul 8, 2005 09:43 AM
DC4_MADMAN
11
Jul 6, 2005 06:10 PM
