Check Indicator
Old Mar 3, 2002 | 06:32 PM
CWITR's Avatar
Default Check Indicator
My check indicator came on. I think my gas cap was loose , so I figured it was as the manuel says. I have driven it like four times after, but the light has not gone off. Anyone else have this problem.
Old Mar 3, 2002 | 06:36 PM
Phoenix_ITR's Avatar
Default Re: Check Indicator (CWITR)
is this the maintenance required light or some other warning light? if it was the main. light, it could just be reminding you that the car is due for a service. if you do all of your own service, as many R owners do, you can reset the light by pushing the button located under the dash, above the drivers right shin.
Old Mar 3, 2002 | 07:13 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
I'm assuming you mean the check engine light? Follow the steps here and let us know what code it is.
Old Mar 4, 2002 | 08:58 AM
CWITR's Avatar
Default Re: Check Indicator (Dominic Toretto)
It blinks 9 short times then 1 long time.
Old Mar 4, 2002 | 09:01 AM
b00st-0wnz's Avatar
you sure? That's a code 19 which doesn't exist to my knowledge.. or is it 9 long and 1 quick? If it is 9 long and 1 short then it's the fuel tank pressure.
Old Mar 4, 2002 | 09:26 AM
CWITR's Avatar
Not sure. How long is a long flash?
How long does it take to reset itself, if it is the fuel cap? I am pretty sure the cap was loose when I checked it.
[Modified by CWITR, 10:27 AM 3/4/2002]
Old Mar 4, 2002 | 10:09 AM
b00st-0wnz's Avatar
From your IM it sounds like code 9. (9 flashes then a pause then 9 flashes) which is.
9 Cylinder Position Sensor Open or short in CYP circuit, bad CYP sensor
Oh yeah, to reset it pull the radio fuse (or whichever it is) in the engine bay for 30 seconds or so (or disconnect the neg batt term).
[Modified by Dominic Toretto, 2:13 PM 3/4/2002]
Old Mar 4, 2002 | 10:30 AM
CWITR's Avatar
If there is something wrong with the sensor, it will go back on , right.
Thanks for all your info.
[Modified by CWITR, 11:31 AM 3/4/2002]
Old Mar 4, 2002 | 10:46 AM
CWITR's Avatar
I unplugged the neg. battery terminal, but the ligh is still on. When you say the fuse in the egine bay, do you mean the 7.5 amp fuse for the radio back up?
Old Mar 4, 2002 | 11:29 AM
b00st-0wnz's Avatar
yes.
Old Mar 4, 2002 | 12:25 PM
CWITR's Avatar
I pulled the fuse, and the light has not come back on. If there is a problem, will it trip again?
Thanks for all the help.
[Modified by CWITR, 1:26 PM 3/4/2002]
BiggieBert
Acura TL, RL & ZDX
Sep 20, 2008 08:59 AM
Corruption
Jun 3, 2006 12:08 PM
laurat
Oct 14, 2002 12:54 PM
under_psi
Aug 16, 2001 12:50 PM
sackdz
Jun 23, 2001 09:36 AM
