Cell Code 22 - What to fix?!?
I pulled my CEL code last night and it came up with "22".
I've had the car at the dealer a couple of times for the same code and they said nothing was wrong and reset the light. The CEL is now tripping at least once per time I drive the vehicle and I'm losing VTEC everytime that happens (unless I shut the car off and then turn it back on).
My question is what should I look to check or replace? The C-Speed Racing site says it a "VTEC Oil Pressure Switch", but the dealer allegedly tested it and said it was fine. Is that the likely culprit or is it something else? TIA.
[Modified by typer_801, 8:08 AM 3/19/2002]
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
22 is VTEC system failure code. It can be the pressure switch, vtec sol, ECU and I think one other item.. check oil level first since it doesn't seem to happen instantly.
yeah i got that too, i was kinda low on oil, filled it up. code never pops up again though.
but whenever i short the service connector, that same CODE 22 comes up!
OK, I religiously check the oil level and it was within the acceptable range (middle of the marks) when I checked it last fillup. At that, I'm getting the CEL code daily.
Dealer checked the VTEC solenoid last time in and it was fine, but I don't remember about the any pressure switch, or further tests they did. Looks like I may have to consult the Bentley....
I will top the oil off tonight and see if that makes a difference before I get too involved though.
integracivic94
Aug 22, 2004 08:42 AM
