CEL coRnfusion!!
Old May 26, 2008 | 08:48 AM
RTW DC2R's Avatar
Default CEL coRnfusion!!
OK so Im running my stock OBD2b ITR ECU. I have a ton of codes, and a constant CEL when the car is on.
Constant CEL is from removing the immobilizer, so whatever no big deal.
The other codes I have are 16 (fuel system/injector/circuit), 54 (crank sensor/circuit), 71 (cyl 1 misfire), and 81 (not even sure what that one is yet).
the strange thing is that I am not even running the secondary O2 yet, and I have EVAP removed and yet the codes for those dont even show up lol.
secondly, I cant seem to reset the ECU. the reset procedure per the manual is to remove the 7.5a BACK UP radio fuse under the hood for 10 secs. did that, all the codes are still there before I even turn the ignition back on. unplugged negative terminal for 5min, the codes still there before turning ignition on...?? why wont these codes clear?
Old Jun 2, 2008 | 06:42 AM
tunerauti's Avatar
to clear the codes un do the positive power (battery) cable for 10 seconds.. also u said obd2... u can just go to like napa or schucks and get that cleared... just ask the for a ecu scan.. its free... takes mins.. and your good. GOOD LUCK MAN
peanut butter
Jan 10, 2008 09:48 AM
liquidxEG
Feb 22, 2005 03:46 PM
fe519
Feb 24, 2004 04:49 PM
denshu
Dec 16, 2003 02:48 PM
genetsang
Jun 24, 2003 12:24 PM
