cel contantly blinking?????
Old Jan 3, 2002 | 12:39 PM
98R #448's Avatar
Default cel contantly blinking?????
Saturday my cel came on. I reset it and it came on again. Long story short My code was74 when i checked it tuesday . A few minutes ago. I just noticed the light was constantly blinking. I shut the car off and turn it back on and it just stays lit with no blinking this time. Im just curious why did it start blinking like that. Maybe its trying to tell me I have another error to check?
Old Jan 3, 2002 | 12:42 PM
ITR764's Avatar
Default Re: cel contantly blinking????? (98R #448)
if your light is on and stays on then it nothing major. if it is blinking then get it to the dealer ASAP!!!! my tech told me a blinking cel is not good!!!
Old Jan 3, 2002 | 01:56 PM
Butterbean's Avatar
Default Re: cel contantly blinking????? (ITR764)
74 means cylinder number four misfire if im not mistaken. I know its for a misfire, but not sure of the cylinder!
Old Jan 3, 2002 | 02:00 PM
sgT's Avatar
sgT
Default Re: cel contantly blinking????? (Butterbean)
71-76 misfire cylinder 1-6
with the ones digit being the cyl #
If the light is blinking constantly, you have a serious problem thats making the ecu
very unhappy. Have you done something to your car recently?
The last time i saw that happen was when I installed a POS crane ignition box
on a civic and it misfired constantly causing the MIL to flash.
Old Jan 3, 2002 | 02:04 PM
ITR 00-1567's Avatar
New User
Check your plug wires. I had this and one was loose on the distributor. You will need to disconnect the battery. (button will not reset this) Hope this helps.
Ian
Old Jan 4, 2002 | 07:33 AM
98R #448's Avatar
Default Re: cel contantly blinking????? (ITR 00-1567)
I think it was blinking because it was trying to tell me I have more error codes. My abs light started showing its azz. I think the weather down here has caused the sensors to get frozen or something.
Old Jan 4, 2002 | 07:54 AM
FAST4DR's Avatar
Default Re: cel contantly blinking????? (sgT)
very unhappy.
Old Jan 4, 2002 | 08:14 AM
Black R's Avatar
25 Year Member
.....mine only blinks if i jump the codes. Otherwise it's on all the time...
Didn't you just get done breaking in this new motor Mike? Damn.
Old Jan 4, 2002 | 08:50 AM
98R #448's Avatar
Default Re: cel contantly blinking????? (Black R)
Theres nothing wrong with the motor. It runs stronger than the last one I think. I havent dyno'd it yet to prove that. It has about 20k miles on it and Im about to change the spark plugs and get a valve adjustment next week. Im real curious to know what it would put out but then again Im pretty sure in the 160-170hp range. I dont feel its reason enough to justify me spending the money to know that. Would you like to bet me?
[Modified by 98R #448, 12:50 PM 1/4/2002]
Old Jan 4, 2002 | 08:54 AM
APEX i GSR's Avatar
Mike give me a call you got the new # right
Old Jan 4, 2002 | 11:05 AM
Keane Rated R's Avatar
Default Re: cel contantly blinking????? (APEX i GSR)
I´ve driven mine in -15 celcius so...
Old Jan 4, 2002 | 12:07 PM
98R #448's Avatar
Default Re: cel contantly blinking????? (Integra Rated R)
thanks, I appreciate that.
Apexi gsr: Your PCS telephone sucks. I think I have your new #. I tried calling you yesterday. Hit me up.
[Modified by 98R #448, 4:09 PM 1/4/2002]
Old Jan 4, 2002 | 12:16 PM
AssPenny's Avatar
I was told when it blinks you are in limp mode... could be wrong though
Old Jan 4, 2002 | 05:06 PM
Butterbean's Avatar
sounds funny but....my abs light came one because my ground wire on the battery was loose.
Old Jan 22, 2002 | 11:56 AM
98R #448's Avatar
oki doki. I replaced spark plugs, wires, distributor cap and rotor. Same code 74 whats next possible. I had a feeling I was wasting my money.
Old Jan 22, 2002 | 12:15 PM
sgT's Avatar
sgT
Default Re: cel contantly blinking????? (AssPenny)
wrong.
it usually blinks when there is ongoing detonation(or what the ECU *THINKS* is detonation.
when you are in limp mode, your rev limit goes down to 6000
Old Jan 22, 2002 | 12:35 PM
98R #448's Avatar
l already tried that. No problem hitting vtec when flashing like continuously. Can this be caused by improper idling, meaning maybe I should adjust the idling screw. My timing had been adjusted to 16-17 degrees a few months ago. ???
Old Jan 22, 2002 | 12:44 PM
sgT's Avatar
sgT
every time i have seen the MIL just blink it was due to detonation problems
and the car ran like crap.
why dont you see what codes you have and let us know.
Old Jan 22, 2002 | 12:58 PM
98R #448's Avatar
same code every time code 74. I guess next is to do compression check. I think I might try adjusting the idle by the screw on the throttle body. everyone talks about how the 2000 and up motors have different cams. My car is a 98 obd2 but i have a 2000-2001 motor?
Old Jan 22, 2002 | 01:06 PM
sgT's Avatar
sgT
do a leakdown as well.
EJ6er
Jun 30, 2011 08:50 PM
SiTR
Feb 14, 2008 04:19 PM
discrete
Oct 24, 2005 07:14 PM
stealth89hatch
Aug 15, 2005 04:48 PM
YellowR2000x2
Aug 30, 2002 08:23 AM
