cel code 90
Old Nov 3, 2003 | 03:18 PM
davidjaii's Avatar
Default cel code 90
Evaporative Emission Control System leak detected in the fuel tank area ... i dont know what needs to be fixed?.... any suggestions
Old Nov 3, 2003 | 03:40 PM
tilt's Avatar
Default Re: cel code 90 (davidjaii)
try a new gas cap.
Old Nov 3, 2003 | 04:37 PM
integraL's Avatar
Default Re: cel code 90 (tilt)
wanna try taking it to acura? it may cost a little, but its worth it for your teg
Old Nov 3, 2003 | 05:07 PM
Alexander's Avatar
Default Re: cel code 90 (integraL)
I have had code 91 for the past 6 months if that helps
Old Nov 3, 2003 | 05:49 PM
davidjaii's Avatar
err wut did u do to fix it......
Old Nov 3, 2003 | 06:36 PM
Alexander's Avatar
Default Re: (davidjaii)
I got used to the orangish-yellow Check Engline Light.
Old Nov 5, 2003 | 02:30 PM
davidjaii's Avatar
its not the gas cap makin the cel go on.... any other suggestions?
Old Nov 5, 2003 | 03:42 PM
tilt's Avatar
just makin sure... did you reset the ecu? just take the neg terminal off the battery for a sec. otherwise, you might want to look under the car and see if you dented the tank or if the fuel lines are knicked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidjaii &raquo;</TD></TR><TR><TD CLASS="quote">its not the gas cap makin the cel go on.... any other suggestions?
CrAzyGsR101
Jan 26, 2005 03:38 PM
weana
Oct 14, 2004 08:36 AM
G_S_R
May 3, 2004 03:17 PM
Aaron M
Mar 17, 2003 11:47 AM
