cel code 14???? what to do
Old Mar 30, 2007 | 10:53 PM
JDM97dc2R's Avatar
Default cel code 14???? what to do
i got my check engine on so i went to see what was wrong and it came out with the code 14.. one long and 4 shorts... i searched what is the meaning on this code and what i found out was
this is what cspeedracing.com says: http://www.c-speedracing.com/faq/05.php
IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
and this is what Team Integra says: http://www.team-integra.net/se...ID=34
Electronic Air Control
so now my question is what should i do now in order to fix this problem.. do i have to clean? replace? what is it to do?
thanks in advance
Modified by JDM97dc2R at 4:15 PM 4/1/2007
Old Mar 31, 2007 | 09:09 PM
JDM97dc2R's Avatar
Default Re: cel code 14???? what to do (JDM97dc2R)
anyone?
Old Mar 31, 2007 | 10:34 PM
WickedKP's Avatar
Both of your links lead to the same web site. Fix that 1st
2nd Clean the Air control. there is a small filter that might be a little cloged.
Old Mar 31, 2007 | 11:16 PM
JDM97dc2R's Avatar
Default Re: cel code 14???? what to do (WickedKP)
ok link fixed.. thanks will check it out.. where is the air control?
Old Apr 1, 2007 | 11:53 AM
WickedKP's Avatar
It's located on the intake near the firewall side. It's been a while i belive it's held on by 2 x 10mm or 12mm bolt.
Old Apr 1, 2007 | 12:10 PM
BMaDOHC's Avatar
take iac off throttle body. its got 2 coolant lines going to it. then soak in a rust penetrant for awhile. should loosen up spring inside of the iac valve.
Old Apr 1, 2007 | 05:56 PM
WickedKP's Avatar
Default Re: cel code 14???? what to do (BMaDOHC)
No thats the cold idle. the electronic is located on the intake manifold near the firewall. has 2 bolts and a two wire plug going to it. just remove you will see the small filter probley cloged. just clean and try it out. alot time that just the problem.
Old Apr 2, 2007 | 12:09 AM
JDM97dc2R's Avatar
so that means that there is no sensor or anything? just cleaning it will do? should i clean it with any liquids(sovents) or just comressed air?
will be nice if anyone got any pictures of it
Modified by JDM97dc2R at 6:14 PM 4/2/2007
vtec_ef8
Apr 9, 2010 10:26 PM
SLEEPIN-GSR
Jun 23, 2009 02:06 PM
slacks
Sep 11, 2007 04:19 PM
civic4dr2000
Apr 2, 2006 04:41 PM
cipherpimp
Dec 5, 2001 08:44 PM
