car pulls right when accelerating
Old Sep 16, 2008 | 02:05 PM
honda_guy58's Avatar
Default car pulls right when accelerating
Just recently started, it pulls slightly to the right only when I accelerate. The steering wheel is straight and it brakes in a straight line and does not pull when i keep the throttle at a steady position. Any ideas?
Old Sep 16, 2008 | 02:13 PM
01_ITR's Avatar
Default Re: car pulls right when accelerating (honda_guy58)
maybe you dont notice it as much when ur driving at a steady rpm, but when you accelerate you are going to notice a pull much more. Try to get it aligned.
Old Sep 16, 2008 | 02:15 PM
UCI_Type-R's Avatar
Default Re: car pulls right when accelerating (01_ITR)
could be ur alignment or u might also want to check your tire pressure......sometimes with severel PSI differance on the twofront tires it will tend to pull to the side with a lower PSI. IMO
Old Sep 16, 2008 | 02:24 PM
I was thinking alignment also but I know that it never did this before.
Old Sep 16, 2008 | 02:26 PM
Scotty2H's Avatar
Default Re: (honda_guy58)
Cars can loose their alignment.
Old Sep 16, 2008 | 02:54 PM
grjp1988's Avatar
I had the same problem when my cars tires were really worn. I changed them and now it fine
Old Sep 16, 2008 | 04:46 PM
tires are brand new, I just installed them about 1000 miles ago.
Old Sep 16, 2008 | 05:36 PM
Eva01's Avatar
Torque steer perhaps.
Old Sep 16, 2008 | 07:08 PM
Arsenal's Avatar
Default Re: (Eva01)
Passenger axle (cv joint)
Had this happen 3 times, to diff. sides, usually when replaced with an autozone axle after a couple months.
Switched to raxles and haven't had the problem since.
Old Sep 16, 2008 | 07:17 PM
Kenso's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_guy58 &raquo;</TD></TR><TR><TD CLASS="quote">tires are brand new, I just installed them about 1000 miles ago.</TD></TR></TABLE>
Possibly a defective tire, I've seen it on several occasions. Especially since they were just installed, and the problem just started. Simple test, try swapping the front wheels from side to side, and see if the pull switches directions.
jmccalip
Apr 24, 2008 06:38 PM
Ricey McRicerton
27
Sep 14, 2005 08:30 AM
deviant1
Mar 29, 2005 08:17 PM
Jer'rome
Aug 15, 2004 09:03 PM
GapxGuy
22
Jun 12, 2004 03:16 PM
