Bye bye engine !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">I don't understand why people don't use their heads & use a revlimit.
Depending on the motor setup i.e. cam profile, compression ratio, general flow etc.
99% of the time a 1.8L setup with itr cams will stop making positive power after 8500 rpms. I.E. a revlimit of 9,000 rpms would be the highest you would need to set your revlimit.
There is no reason to be taking a motor past 9,000 rpms which does not produce power over 9,000 rpms.
Dont think rev limiter works in a downshift like this. or are you meaning something else?
This guy already said his friend mis-shift to 3rd instead of 5th at 9k.. It might sounds dumb, but this is why i recommand most people get the mugen or spoon shift linkage bushing.
mis shift can still happens, but much less chance and its extememly useful during track days.
</TD></TR></TABLE>Dont think rev limiter works in a downshift like this. or are you meaning something else?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R »</TD></TR><TR><TD CLASS="quote">
thats why i sarcastically posted "lets play ignorant honda-tech poster"...
and then you go and post "I could only imagine what would've happened if this car was boosted." like you thought i was serious.
Ahhh my bad..I didn't see the top part of your post.
</TD></TR></TABLE>Ahhh my bad..I didn't see the top part of your post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondabitch »</TD></TR><TR><TD CLASS="quote">
to the original poster...best of luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4KiD »</TD></TR><TR><TD CLASS="quote">Ouuch.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 »</TD></TR><TR><TD CLASS="quote">
Dont think rev limiter works in a downshift like this.</TD></TR></TABLE>
Exactly. A rev limiter cannot prevent a mechanical over-rev (i.e. mis-shift).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">
Do some motors make negative power after 8500?
yes... but may catch fire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">To the OP:
I was waiting for this... JB-weld FTW.
</TD></TR></TABLE>I was waiting for this... JB-weld FTW.
Rebuilding the block and then will sell it off.
The only thing we salvaged from the head is the ITR cams, Toda Valve spring.
Will be buying a ported B16A head from a friend and then mating it to a B20B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R »</TD></TR><TR><TD CLASS="quote">I think your friend should consider purchasing a car with an automatic transmission.</TD></TR></TABLE>
insert pic of stewie with caption "oh yeah, i went there." here.
FAST4DR
18
Mar 12, 2002 02:11 PM
