Bouncing off the rev?
Old Apr 20, 2004 | 07:18 PM
top fuel's Avatar
Default Bouncing off the rev?
i was watching the best motoring type r video and i noticed they bounce off the rev before they shift, is that for the full effect or something? i thought it would delay your timing of the quarter mile or time for the track
Old Apr 20, 2004 | 07:20 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Sometimes you just bounce off it to delay the shift till outta the corner. actually should be faster.
Old Apr 20, 2004 | 07:26 PM
vtec.dc2's Avatar
Default Re: Bouncing off the rev? (top fuel)
don't bounce of fuel cuttof at high rpm if you don't have to. learn to shift before reaching that point.
Old Apr 20, 2004 | 07:56 PM
SleepnCiViC's Avatar
i jus liek the sound haha
Old Apr 20, 2004 | 08:05 PM
nightrider's Avatar
if necessary, it's ok. all the time, i don't think it's good at all. i've only bounced off the rev limit twice and that was on the dyno.
Eluder200K's Avatar
Default Re: (SleepnCiViC)
If you hit the limiter it will slow you down, sometimes you see it at the track thought because it can be faster. Depending on the track layout it can be faster to just leave it in gear and hit the limiter then to shift right before you brake for a turn.
Old Apr 21, 2004 | 05:06 AM
B18C R Spec's Avatar
Keiichi Tsuchiya ROCKS
Is not safe to red line to the point of reaching fuel cutoff but if you know what you're doing like Tsuchiya there is no need to explain.
We'll miss you Tsuchiya
Old Apr 21, 2004 | 05:30 AM
Opie's Avatar
I hit the limiter often no probs here except slow 1/4 mile times and churning noises in my tranny
Old Apr 21, 2004 | 06:07 AM
Jon D's Avatar
Default Re: (opie)
I do it very seldom...but once in a while by accident. Not the best idea but wont hurt anything or shouldnt anyways if your doing in once in a blue moon.
Old Apr 21, 2004 | 12:15 PM
itr1275's Avatar
The rev limiter is a protection from overreving your motor. If the protection damages the motor thens it's not really protection .So in theroy you should be able to bump the rev limter all day long and it is no worse than redlining your motor.
This is just theroy, so if you (or anyone else) blow up a motor while hittting the reve limter too bad.
BTW I have no quams with bouncing mine off the limiter.
Old Apr 21, 2004 | 12:24 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: (B18C R Spec)
Hitting the rev limiter in a stock car should not damage the motor. Just like making the ABS engaged won't damage your brake system. But of course it is better not to do it excessively.
Sometimes it is faster to leave it in gear and let it bounce a little, than to upshift then downshift again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C R Spec &raquo;</TD></TR><TR><TD CLASS="quote">We'll miss you Tsuchiya</TD></TR></TABLE>
What do you mean? Did he die?
dc2_916
May 17, 2008 06:56 AM
.M.
Jun 10, 2004 09:29 AM
95civicracer
18
Feb 19, 2003 06:34 PM
JDM 007
Sep 17, 2002 04:41 PM
