b20 torque + reliability
Old Sep 9, 2001 | 08:20 PM
ezark's Avatar
Default b20 torque + reliability
Just wondering, have an all motor setup / motor is pretty much done except for bottom. I am not satisifed with my torque right now 134/tq. Will the torque difference be great with the b20? How would the reliability be on the over all motor (anyone hear of any problems with b20's in tegs)?
99 GSR
Thanks.
Old Sep 9, 2001 | 08:40 PM
H-PIMP's Avatar
Default Re: b20 torque + reliability (krazE)
A friend of mine has a '99 B20/VTEC with a GSR head, Skunk2 manifold, ITR throttle body, ITR cams, JDM header, APEXi N1. In a 92 Civic HB. The car runs mid 13's on muscle with 15 inch street tires. Need I say more?
Old Sep 9, 2001 | 11:39 PM
GZR4DR's Avatar
Default Re: b20 torque + reliability (H-PIMP)
So finally thinking about the B20 huh CJ?
If you want more torque, its the best route. Plus you have your GSR block on reserve just in case anything should happen. Or you could sell it and help pay for the B20 motor.
Old Sep 10, 2001 | 07:18 AM
Black R's Avatar
25 Year Member
My buddy is beginning a project like this as well - but for a crx...
I say check out the crvtec.com and b20.net for more info.
As long as you get oil squirters and vtec lines, it should be fine... Maybe something to tune with for air and fuel...
I'm no expert... If you're buying a short block, you might want to upgrade the crank, pistons, and rods before installing...
Old Sep 10, 2001 | 07:26 AM
Hooch'n's Avatar
Default Re: b20 torque + reliability (Black R)
For drag racing a B20 in a Civic does real well. I had a good conversation about this topic the other day, I was supprised by how much you can get out of those things.
Old Sep 10, 2001 | 07:31 AM
H-PIMP's Avatar
Default Re: b20 torque + reliability (8400-RPM)
Actually '96-'98 B20's are not that desireable. They have less torque/less hp and do not respond to VTEC conversion as well as the '99-'01's do. Another plus is that a GSR head will bump up compression by .02 points as opposed to an SI/ITR head.
Stock internals are ok if you plan on running OEM cams, and no FI. Like I said in my post above. My friend has a bone-stock '99 B20 bottom end (stock pistosn, rods, crank) with a GSR head. And it screams! It runs mid 13's in a street HB w/ a '95 GSR ECU and hardly any tuning at all.
[Modified by H-PIMP, 11:33 AM 9/10/2001]
roger93si
Jan 26, 2007 08:51 AM
outtacontrolsol
Dec 21, 2006 09:18 AM
W.O.P.
Sep 21, 2004 12:31 PM
maxxdout
Oct 24, 2002 11:35 PM
StorminMatt
Feb 28, 2002 05:26 PM
