B20
Old Apr 26, 2007 | 07:00 AM
clutch6racerone's Avatar
Default B20
Would it be a good thing to put a b20 block on a type R i plane to bore it out to a 2.1-2.2 what approach should i take to if i do put a b20 block it
Old Apr 26, 2007 | 07:02 AM
94rs-turbo's Avatar
Depends on what you are trying to do. B20 sleeves are weak and it better to get them sleeved but you can sleeve a LS block do do the same thing
Old Apr 26, 2007 | 07:12 AM
Default Re: (94rs-turbo)
I want to build a all motor type R
Old Apr 26, 2007 | 07:33 AM
Bradstard's Avatar
Default Re: (clutch6racerone)
If you are going to bore that big you will need to resleeve. Just about any B-series block will work then.
94rs-turbo's Avatar
If you building it just use a gsr block(same thing as ITR) or an LS block sleeve either one doesnt matter since your going to build it, well if your doing crank pistons rods. Or you could got the cheaper route GSR block and i think ls crank and rods with oversied itr pistons makes good power
Old Apr 26, 2007 | 05:34 PM
doood's Avatar
been there done that
Default Re: B20 (clutch6racerone)
you're going to need a very big bore if you want that much displacement. might even need to stroke it too.
ghosthatch
Oct 4, 2010 12:08 AM
lakai_19
Feb 13, 2008 04:08 PM
lakai_19
May 21, 2007 02:25 PM
Boostless97Lude
Nov 20, 2002 09:11 PM
TypeR0149
Aug 22, 2001 12:32 AM
