airbag cancel plug
New User
Re: airbag cancel plug (IGGY)
it should be under the steering column...mine is a SRS service plug...but it's connected to the little door. If this isn't what your talking about, sorry, but it looks the same.
Global Moderator
The ITR comes with one, you just have to plug it in.
It's in your steering column.
All cars that come with airbags come with plugs to disable them.
Re: airbag cancel plug (Reid)
Re: airbag cancel plug (makibaka)
I curious if you can put in a resistor the exact resistance as the airbag in the plug to fake out the computer so the pass. airbag will remain functional. I've done this for a customer's Jeep Liberty but I wonder if it'll work for us?
Re: airbag cancel plug (jonnybravo)
quick airbag Q.. when installing airbag, should you connect batt. then plug it in, or plug it in then connect batt.?? or does it not make a diff. cuz i heard they can blow if done incorrectly.
Re: airbag cancel plug (UltraPrince)
Older Honda/Acura SRS systems had a short connector in the steering column cover. Newer Honda/Acura SRS systems use a self shorting connector( looks like the connector for the RSX is your first post). What are trying to accomplish? Remove the passenger airbag to save weight? If that is what you are trying to do, you will need to trick the SRS ECU into thinking that the passenger airbag is connected and functional.
Chrislow
36
12-13-2002 07:00 PM
