Abs cel light...Help please
Old Aug 12, 2004 | 10:49 AM
JDM97R's Avatar
Default Abs cel light...Help please
Hi,
my friend's jdm itr 98 spec has the abs cel light on and flashes 31.
Can somebody tell me what is the soloneid?
Thanks
Old Aug 12, 2004 | 10:51 AM
Jdm 98spec R's Avatar
Default Re: Abs cel light...Help please (JDM97R)
help us pls.. i'm worried..
Old Aug 12, 2004 | 12:40 PM
Willard's Avatar
Default Re: Abs cel light...Help please (Jdm 98spec R)
31 = FR (solenoid short to body ground/short to wire)
I just checked my ABS code and it is 16 = RR wheel sensor (electrical noise/intermittent interuption).
I guess I need to clean the brake dust off of the sensor again.
Old Aug 12, 2004 | 02:15 PM
JDM97R's Avatar
Default Re: Abs cel light...Help please (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">31 = FR (solenoid short to body ground/short to wire)
I guess I need to clean the brake dust off of the sensor again.</TD></TR></TABLE>
Does any body knows where to check or how to replace?
Old Aug 12, 2004 | 02:34 PM
vteec's Avatar
help us pls ....
Old Aug 12, 2004 | 08:26 PM
Default Re: Abs cel light...Help please (vteec)
ttt
Old Aug 13, 2004 | 04:09 AM
hepl us out pls...
Old Aug 13, 2004 | 09:13 AM
mstewar's Avatar
check that the ABS harness is grounded, ie, attached to the chassis near the ABS pump(directly in front if I remember off hand, under the airbox?)..
Old Aug 13, 2004 | 09:32 AM
Default Re: Abs cel light...Help please (mstewar)
thanks guy.. more pls???
Old Aug 13, 2004 | 10:12 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm 98spec R &raquo;</TD></TR><TR><TD CLASS="quote">thanks guy.. more pls???</TD></TR></TABLE>
did you check that?
Old Aug 13, 2004 | 10:31 AM
yes.. i fixed it at last!!
guess what... the main abs wire that is screwed with the positive terminal was loose!!!
thanks for the help
rgrds
FasterScooter
Honda CR-V & Element
Jan 21, 2013 06:57 AM
rhino87
May 30, 2009 11:48 AM
BLacK FirE
Apr 26, 2005 01:56 PM
FK00GSR
Apr 25, 2004 04:09 PM
vtec4gcivic
Dec 1, 2003 02:06 PM
