P08 manual ECU CEL codes
Done a couple of searches and checked the usual suspect sites but no luck, can anyone help out with a full list of P08 ECU codes. I have the P28 list, but there will be different codes on there, like knock sensor and no heated 02 sensor, anyone got the info?
Re: P08 manual ECU CEL codes (japspecjohn)
Ok, so they are the same basic codes, just wondered if they were any different, it being a Jap ECU and all.
Can anyone confirm what a 0,1 and 10 code look like, i am getting a very intermittent CEL light, which gives 1 longish blink, is that a ECU, O2 or intake temp sensor problem?
And i was told there was a knock sensor on the P08 ECU, if so can you tell me what pinout it is, and if it gives a CEL light when it senses knock, or just when it goes wrong.
Or is there no knock sensor?
Re: P08 manual ECU CEL codes (CivicESi)
P08 has the same codes as P28 and any sohc vtec d-series ecu NO KNOCK SENSOR
with an exception in :
- no code 41 which is the heating element
- no code 13 which is a BARO (PA) sensor
- if you are getting code 10 (1 long blink) its IAT (intake temp sensor), 1 short blink = 02 sensor.
thanks to Katman again review the following:
knock sensor CEL is on, replace ecu replace knock sensor and the CEL is still lighted up!!!!!!!!!!!!
Kangolbrand
08-23-2006 09:23 PM
