1st Gear Problem
Old Nov 15, 2001 | 01:07 PM
Type R 702's Avatar
New User
Default 1st Gear Problem
Im sometimes having problems getting my car into 1st gear from neutral im wondering what can cause this? I had my clutch and flywheel replaced because the pressure plate broke and was wondering if when the acura techs took it for a test drive with a broken pressure plate(not knowing it was broken) if that couldve caused any further damage or wear to the car?
Old Nov 15, 2001 | 01:20 PM
Cosworth's Avatar
Default Re: 1st Gear Problem (Type R 702)
have you always had this problem? if not, it's normal. Mine is hard to get in the 1st gear as well. You just gotta put it into 2nd before putting it in the 1st. Sometime chagning out your tranny fluid helps a bit.
Old Nov 15, 2001 | 01:31 PM
B2FiNiTY's Avatar
1st gear is the toughest gear to get into for. Especially from a rolling start. Sometimes it'll go in smooth from a standstill but most of the time it just doesn't feel like a solid shift.
Old Nov 16, 2001 | 11:07 AM
Sa-Da-Teh's Avatar
New User
I have a problem with first. If I sit at a light for awhile, sometimes first won't go in. I usually have to put it in second and pop it into first (sometimes kinda hard). I took it in for warranty, but they couldn't duplicate the problem, no work was done.
I don't have a problem with putting it in first from a rolling stop, I just hate holding the clutch down waiting for the light.
Old Nov 16, 2001 | 12:24 PM
ITR632's Avatar
Default Re: 1st Gear Problem (ITR-01-0871)
Ditto
Old Nov 16, 2001 | 12:56 PM
fangtl's Avatar
Default Re: 1st Gear Problem (ITR632)
ditto for me too
jrdc5r
Transmission & Drivetrain
Feb 19, 2019 10:57 AM
Ricextacy
13
Mar 17, 2009 07:57 AM
integraboi1010
Mar 5, 2007 09:14 AM
creepy116
Dec 11, 2006 12:21 PM
maxpsi
Jun 16, 2003 01:40 PM
