00-0016 Restoration Begins
#51
Re: 00-0016 Restoration Begins
Hood is on. Fitment is about on average and cant complain. Lip fits well for a sub-300 dollar piece that I consider a wear item almost.
pics because you asked! The lip is NOT MOUNTED. Im just test fitting it using my patent pending method.
#52
You sir, are a gentleman.
How does the carbon weave look and all that ****? I am going to pull the trigger on one as well since I just found out my Seibon lip is about 16 weeks out, which is ridiculous. If I can save even a bit more and still have a nice piece that I too see as a wear item, I'm game.
Love the cushon idea.
#54
#55
Ordered mine today. Can't wait to get it on. My front end needs a lip so bad.
Also ordered suspension....oh boy....
#57
How does one define quality? Are you the arbiter of that?
We all make a value judgement, when it comes to spending our money. I appreciate you taking the time to comment, but I don't find it particularly constructive in this instance.
#58
Exactly. While OEM is very good and I generally run with it myself, in a few areas you can improve on stock. More adjustability etc. So long as you avoid the five quid eBay unbranded "upgrades" made from the finest chinesium and go with well regarded names like Spoon, Mugen, etc and a host of smaller outfits that do quality work you can't go wrong. Good call on the Meister R's
#59
Lip will be there tomorrow.
#60
Apropos of **** all really ET, but I was going through my maintenance and the like receipts I've kept since I got my R in 2005 and found I installed those coilovers on the 10th of September 2010. Seven plus years on and 50,000 miles, often on roads that NASA could have tested the Apollo Moon buggy on and they're still working the way they promised. No doubt they've lost something in the interim, but whatever loss there is is consistent across the four corners. Over here in Ireland we have an annual NCT(National Car Test. They were inventive that day...) and among other things it measures suspension travel and the left/right readings have remained almost exactly the same in the seven tests the car's been through. That's pretty impressive for coilovers, which can be fantastic setups, but not generally known for longevity compared to stock.
The longevity is one big reason I've recommended them to people on the interwebs and in Real Life™. That and the fantastic customer service(which I haven't needed). Maybe I should chance my arm and ask the Jerrick lad for a bit of a discount on the next set, only problem being I don't bloody need a new set. Crap!
Caught your latest Youtube about fitting the lip. Looking good. The rust in your arches looks pretty minor and being in Arizona really helps, unlike in my country shaped sponge*. Maybe another project of sorts might be to look into the various parts of your car to check for the tin worm and apply some anti rust wax? The wax is cheap and it's pretty much the time and effort to remove the rear interior panels to check and it's an easy job. Because the actual wheelarch lips look pretty solid, the rust you have in the arches might be coming from the inside out because of leaking rear light seals? A very common problem on these and it's down to the design and Honda light gaskets. They're very thin even when new and after nearly two decades the originals will be pretty crap. I'd not buy new Honda ones though. They're silly money IMHO(I'm cheap) and there's a company in Hawaii IIRC? that sells the same pattern but made from much thicker neoprene. Works a treat.
One big rust point with these and about the biggest pain in the you know what is the bottom of the rear quarter panels. This thread on the UK R forum gives a good idea of what to look for.
*There's a reason you find redheads in my part of the world. Even hair rusts.
#61
Can any of you lovely gentlemen measure your ride height, from the middle of the centercap? I am trying to dial in the rear as the new suspension is in. Trying to get a measurement for stock, so I can work from there. I forgot to measure before removing the stock set up. Thanks!
topshot-rhit
Honda Civic (2001 - 2005)
02-26-2013 12:38 PM
IOSUA
01-14-2008 09:53 PM
