will this drain plug work?
Old Dec 16, 2003 | 12:06 AM
oMek's Avatar
Default will this drain plug work?
http://cgi.ebay.com/ebaymotors...46100
for a 95 gsr
Old Dec 16, 2003 | 12:24 AM
WhitEdRift's Avatar
Default Re: will this drain plug work? (oMekoneDC2)
I thought Integra drain plugs were larger than that, something like 17mm. Hmm...can't remember anymore; do too many oil changes hehe. Just check a manual or something for the bolt size and you're all good. In fact I'll check my book and see if it is the same. Although mine is for a 2nd gen.
Old Dec 16, 2003 | 12:25 AM
IN VTEC's Avatar
You might wanna look into the GReddy one. They're around $7 to $9.
Altho, everybody lists the thread pitch as 1.25. I'm wondering if that's correct b/c 1.25 seems too fine to be used on any oil drain bolt that I've seen. I've seen come Japanese sites list them as 1.5.
16400514
You can get them from aieonline or wiredspeed.
Old Dec 16, 2003 | 12:29 AM
WhitEdRift's Avatar
Default Re: will this drain plug work? (WhitEdRift)
Looks like it is 20x1.5 for 1st and 2nd gen. Guess it could be different, maybe 14x1.5 like that eBay one is. Better wait for someone with a newer book.
Old Dec 16, 2003 | 12:30 AM
thaiphob's Avatar
Nikon!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhitEdRift &raquo;</TD></TR><TR><TD CLASS="quote">I thought Integra drain plugs were larger than that, something like 17mm. </TD></TR></TABLE>
the head of the bolt is 17mm but the actuall thread is 14mm
Old Dec 16, 2003 | 12:31 AM
88civicHB703's Avatar
my drain plug is 14mm and my cousin &lt;-- retapped 17mm.. both are G2 Integra..
my 2 cents
WhitEdRift's Avatar
Default Re: will this drain plug work? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Altho, everybody lists the thread pitch as 1.25. I'm wondering if that's correct b/c 1.25 seems too fine to be used on any oil drain bolt that I've seen. I've seen come Japanese sites list them as 1.5.
It is definitely 1.5 as far as thread pitch goes.
Old Dec 16, 2003 | 07:43 AM
IN VTEC's Avatar
It is definitely 1.5 as far as thread pitch goes. </TD></TR></TABLE>
The GReddy one?
Old Dec 16, 2003 | 10:27 AM
WhitEdRift's Avatar
The Greddy one I dunno. The OEM one is though. If you can match that chances are they will fit. Better check to see if 3rd gen's use 14x1.5 though if he is going after the eBay one still.
Old Dec 16, 2003 | 10:30 AM
IntEGNYC's Avatar
dunno if there's any real purpose for having a thermostat from the drain plug since your thermostat already measures the temp of your oil . hmm
Old Dec 16, 2003 | 10:31 AM
IN VTEC's Avatar
I know the 3rd gen's use a M14x1.5...even tho you can eyeball it next to a tranny bolt or whatever, it's been confirmed with a thread pitch gauge.
I'm just trying to find out if the GReddy temp sensor adapters are 1.25 or 1.5 thread b/c I've seen both listed.
Louka Grenon
Acura TSX
Jul 31, 2019 01:53 PM
kingdeadguy
Feb 29, 2012 04:39 PM
Clairvoyant
15
Jun 21, 2006 09:42 AM
coupon
May 8, 2005 07:08 PM
zomart
Oct 24, 2003 11:51 PM
