Oil Drain Plug
Old Oct 19, 2003 | 11:21 AM
zomart's Avatar
Default Oil Drain Plug
my damn drain plug and washer are rusted.
what should i replace them with (on a 95 gsr)? would just a 14 mm bolt and 14 mm washer work, or should i buy one that's specifically made to be a drain plug for my car?
also, why does a 17 mm socket fit my plug if it's supposed to be a 14 mm?
Old Oct 19, 2003 | 11:51 AM
Loveless's Avatar
Default Re: Oil Drain Plug (zomart)
it's 17, not 14
I changed my integra and firend's cl last nightn, both are 17mm
Old Oct 19, 2003 | 11:57 AM
zomart's Avatar
Default Re: Oil Drain Plug (Loveless)
weird... check this out:
https://honda-tech.com/zerothread?id=647768
M14 = metric 14 (14 mm) right?
every website i've been to that sells oil drain plugs for integras has said they are 14 mm bolts...?
Old Oct 19, 2003 | 01:26 PM
thaiphob's Avatar
Nikon!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">it's 17, not 14
I changed my integra and firend's cl last nightn, both are 17mm</TD></TR></TABLE>
the thread pattern on the bolt is 14mm. the head of the bolt is a 17mm
Old Oct 22, 2003 | 10:40 PM
Loveless's Avatar
Default Re: Oil Drain Plug (thaiphob)
lol, I am an idiot
Old Oct 22, 2003 | 10:51 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">lol, I am an idiot </TD></TR></TABLE>
doh you get an E for E-ffort and 1/2 points.
Old Oct 23, 2003 | 03:30 AM
Gerhard_001's Avatar
Go to the dealership and buy another, also did you drive over salt or some radioactive chemical to get your drain plug and washer to rust?
Old Oct 23, 2003 | 03:59 AM
ebelp's Avatar
Default Re: Oil Drain Plug (Gerhard_001)
My drain plug is 17mm. I guess mine isn't oem...
Old Oct 23, 2003 | 04:15 AM
furious94ls's Avatar
Default Re: Oil Drain Plug (ebelp)
I'm sure the dealer is gonna rip you off, but its the best replacement to get.
Old Oct 23, 2003 | 01:09 PM
THE94GSR's Avatar
Default Re: Oil Drain Plug (furious94ls)
get a magnetic spoon drain plug
Old Oct 23, 2003 | 01:26 PM
timmy8151's Avatar
Default Re: Oil Drain Plug (THE94GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE94GSR &raquo;</TD></TR><TR><TD CLASS="quote">get a magnetic spoon drain plug </TD></TR></TABLE>
If you don't want to spend too much money just get a magnetic plug at Napa or Pepboys. I think they're only a couple of bucks.
Old Oct 23, 2003 | 03:11 PM
n0 iNTegRiTY's Avatar
i just don't understand how one gets rust on the OIL pan
How many miles do you go in between oil changes?
Old Oct 23, 2003 | 06:11 PM
RedGSR's Avatar
Just go buy one from dealer. OEM honda drain bolt doesn't rust. They only charge you $3 or so...... You can call that rip off, but it is only $3
Old Oct 24, 2003 | 11:47 PM
SOHCVTECx2's Avatar
Just go to the dealer to get a new one... Dealer products usually don't go bad its only like $2.50
Old Oct 24, 2003 | 11:51 PM
mickey513's Avatar
You can get one from your local part store. Ask them to get the ones in the BACK, not those one in packages located on the isle. The ones your buy from your local part store are IDENTICAL to the OEM ones if you get the right one, same goes for radiator drain plugs.
Clairvoyant
15
Jun 21, 2006 09:42 AM
coupon
May 8, 2005 07:08 PM
B18CYAAA
Apr 18, 2004 04:39 PM
ShiftDown
Jul 30, 2002 11:44 PM
