will the car run normal without the o2 sensor plugged in?
Old Sep 19, 2002 | 08:06 PM
  #26
juniordc2's Avatar
Default Re: will the car run normal without the o2 sensor plugged in? (TimoneX)
you are correct.. 14ohms is what it should be at or.. 10-14 ohms.. and when I measured.. I got a big ZERO, and my dad is an electrician and he measured it too, just incase I did something wrong, he got a zero too.. i didn't get a chance to measure the voltage though.. doesn't the car have to be on for that?
Old Sep 19, 2002 | 08:10 PM
  #27
TimoneX's Avatar
New User
Default Re: will the car run normal without the o2 sensor plugged in? (dc2gsr94)
Ja. Gets hot under there too! Be careful. I ran wires to it and tested it from in the cockpit.
TimoneX <------- not as dumb as he looks....er....n/m
Old Sep 19, 2002 | 08:13 PM
  #28
juniordc2's Avatar
heh, i didn't want to turn on the car on the jackstands and measure the voltage.. but I guess I need a new o2.. did u get resistance on your sensor?
Old Sep 19, 2002 | 08:23 PM
  #29
TimoneX's Avatar
New User
Yup. Got voltage at the primary O2 sensor too, but lucky me I got another O2 sensor to ruin it for me. The secondary has +voltage but no ground...this took me awhile to sort out. I hunted down the wire leading from the - side of the secondary O2 sensor heater circuit to the ECU with an ohmeter. That's when light dawned on my marble head. It's the ECU that's at fault. Sure enough pretty as punch there's a chip blown all to bits. Here I am, being a good boy and running the stock cat...not trying to get away with nothin' and MY circuits blow up?!? Others put resistors inline, fabricate O2 simulation circuits and all sorts of stuff. That'll teach me to follow the rules.
Old Sep 19, 2002 | 08:39 PM
  #30
juniordc2's Avatar
heh.. i'm running a stock cat too.. dunno why my first o2 blew out.. ah.. i hate how its important for air/fuel mixture
Old Jun 26, 2017 | 11:17 PM
  #31
f22b2's Avatar
Post Re: will the car run normal without the o2 sensor plugged in?
i own 97 Honda accord i replace the catalytic but the new one don't have o2 sensor connector what i can do
Old Dec 26, 2017 | 01:24 PM
  #32
Fred Waldbeiser's Avatar
Default Re: will the car run normal without the o2 sensor plugged in? (Salvatore Leone)
Originally Posted by juniordc2
meaning i'll be slower and produce less horsepower right?
Old Dec 27, 2017 | 01:51 PM
  #33
JDM-EJ698's Avatar
You do realize this thread is from 2002 right??
itzyaboyzeem03
Oct 16, 2008 11:15 PM
urquidezj
Jun 19, 2007 10:16 PM
arjusmc
Oct 23, 2003 04:26 PM
tonylude94
Aug 21, 2003 01:26 PM
