wierd noises
Old Jan 24, 2005 | 07:49 PM
dick_213's Avatar
Default wierd noises
i recently installed my timing belt and heard a wierd clicking noise afterwards. i then noticed that the plastic piece behind the cam gears was grinding against them. i fixed that problem but still hear the same noise. i have isolated the noise to the intake manifold. i have no clue what it could be, but the noise seems to dissapate a bit as the car comes to normal operating temp. any ideas guys? it makes my car sound like a pile of ****.
Old Jan 25, 2005 | 06:23 AM
dick_213's Avatar
Default Re: wierd noises (dick_213)
nobody?
Old Jan 25, 2005 | 06:51 AM
LsVtec98's Avatar
did you time it right? could be your valves hitting....better hope not though, bend the crap out of them...
Old Jan 25, 2005 | 12:19 PM
dick_213's Avatar
Default Re: (LsVtec98)
no its definitly not that, the car would run like **** if it was. i just dont understand what could be rattling in the area of the intake manifold.
Old Jan 25, 2005 | 12:21 PM
qcktegls's Avatar
Default Re: (dick_213)
Check ur installation and see if ne teeth are skippin and nothing else is grinding. does it grind when ur just idleing or only when your driving?
Old Jan 25, 2005 | 05:37 PM
dick_213's Avatar
Default Re: (qcktegls)
it grinds when its idling and when driving. it seems like it kinda stops once the engine is warmed up, like its lifters or something. it seems like its coming from the intake mani tho.... no teeth have skipped or it would be running really bad.
Old Jan 27, 2005 | 02:24 AM
TurboEH2's Avatar
lifters ticking? i know my dsm use to do that ALL the time. never heard to many hondas do it tho.
Old Jan 27, 2005 | 02:30 AM
sPaRk'iT's Avatar
Its seem like you need a valve adjustment, every time you change the timing belt you should check your valves too, do some measurements on the valves and see if they are in specs. I have this problem before and it was my valves, they were lose.
Old Jan 27, 2005 | 02:39 AM
tech12's Avatar
Default Re: wierd noises (sPaRk'iT)
Check for loose timing belt. The distributer will rattle when cold if the timing belt is loose.Use a screwdriver like a stethoscope to listen to distributer when running, if you hear the noise in there, then your t-belt is loose.
Old Jan 27, 2005 | 06:22 AM
dick_213's Avatar
Default Re: wierd noises (tech12)
i know its not the valves cause i just adjusted those like a month and a half ago. ill take a looksy at the dist. and get back to you guys. thanks for the help.
HonBlackSol93
Oct 3, 2007 06:05 PM
Teglessb18
Dec 1, 2005 11:53 AM
blackie
Jul 19, 2005 12:07 PM
coupe99vtec
12
Mar 1, 2005 11:20 AM
MKX-R
Jul 9, 2003 12:54 PM
