Wierd Brake problem?
Old Jun 2, 2005 | 04:55 PM
ROOROWNS's Avatar
Default Wierd Brake problem?
HEy
Just changed the Rear pads in my 1991 DA. When i was turning the Caliper Piston back into its bore the dust seal( black boot around caliper piston) Was twisting instead of staying seated. Its kinda hard to explain but instead of the Caliper boot being perfectly seated, its twisted, to what i understand the dust seal is what help return the piston to its bore. Is this twisted boot gonna cause me to drag a cliper. Should i buy a whole new caliper or remove the piston from its bore and fix the seal in a day or so?
Confused?
Sean
Old Jun 2, 2005 | 06:42 PM
Kendall's Avatar
The dust boot doesn't help it return, but damaging the dust boot will negatively affect the life of the caliper. If you can fix the seal now, go ahead and do it.
Old Jun 2, 2005 | 08:55 PM
Muckman's Avatar
Moderator in Chief
Default Re: Wierd Brake problem? (EG_Black_Hatch)
twisting isnt a problem as long as it doesnt tear its ok. Just means its greased well.
mfrs
Sep 9, 2014 03:49 PM
rasinhell
Mar 7, 2005 06:09 AM
BrandonClaps
Sep 20, 2004 09:54 PM
mark72
Sep 22, 2002 08:56 AM
siisgood00
17
Apr 19, 2002 02:34 AM
