Why won't my car warm up properly?
Old 02-11-2003, 02:58 PM
Evan's Avatar
Default Why won't my car warm up properly?
I have a 92 Integra with about a 110 000 miles on it. Well ever since winter hit my car has had a few problems warming up properly, the needle doesn't make it to the 1/2 mark. Anyhow at first I thought it was the thermostat, which I replaced the other day. After I did that the car warmed up like a champ and the heat comming from the vents was great. Now a few days later the same problem is happening, the needle won't make it to the 1/2 way mark and the vent air is cool. I don't know what to do next? Anybody have any idea's? I maintain my car very well, the coolant was replaced a few months ago and the radiator is new and so is the thermostat.
Anyhow if anyone here has an ideas about what I can do that would be very helpful
Thanks a bunch
Evan
Old 02-12-2003, 04:25 AM
JimBlake's Avatar
Default Re: Why won't my car warm up properly? (Evan)
You're in Canada, I bet its kinda cold up there... I'd suggest checking your thermostat, but you already did that. Make sure you bled all the air out. I usually bleed again the day after, & that gets a few more air bubbles.
Its normal to take longer to warm up when its really cold out. Mine does that too. How far do you drive? At -10C mine takes maybe 10 minutes to warm up, when its been parked in a +5C garage. Maybe put a piece of cardboard to block air from maybe 1/3 of your radiator. Then keep watching your temperature gauge in case you blocked too much. Don't forget to take it out in spring .
[Modified by JimBlake, 8:26 AM 2/12/2003]
Old 02-12-2003, 04:50 AM
95gsr's Avatar
Default Re: Why won't my car warm up properly? (JimBlake)
check the antifreeze same thing happened to my car to much water and to little antifreeze
Old 02-12-2003, 07:17 AM
JMX
JMX's Avatar
Default Re: Why won't my car warm up properly? (95gsr)
yeah do a coolant flush, and see if it still does it. was the coolant level low at all last time u checked it.
Old 02-12-2003, 08:54 AM
EL Vap133's Avatar
Is your fan on at all times?
ninjaturtleEG
01-15-2010 11:21 AM
dankstereg6
01-02-2010 10:02 AM
eurodeseo
07-04-2006 06:55 PM
Liquidgsr
12-27-2005 05:41 AM
ex_crxer
04-06-2003 06:52 AM
Quick Reply: Why won't my car warm up properly?
