Why is it or Why Does my engine Backfire?
Old Aug 19, 2004 | 03:47 AM
DriveSideWays's Avatar
Default Why is it or Why Does my engine Backfire?
Why is it or Why Does my engine Backfire? it sounds like it when im at idle and sometimes shift gears. just curious b/c right now it sounds and feels as if my motor is going to go since i dont know whats wrong wit it.
Old Aug 19, 2004 | 04:00 AM
westspeed's Avatar
Default Re: Why is it or Why Does my engine Backfire? (DriveSideWays)
try to change the spark plugs and plug wires or check them
Old Aug 19, 2004 | 04:26 AM
done all that and changed cap and rotor
Old Aug 19, 2004 | 04:15 PM
^bump^
Old Aug 19, 2004 | 05:08 PM
[ iLL ] iNt3GrA's Avatar
Default Re: (DriveSideWays)
i have no cat and my car backfires most of the time sounds kinda cool, not as much of a backfire as those SRT-4's
Old Aug 19, 2004 | 05:19 PM
Padawan's Avatar
Darth ModerVader
A backfire is typically caused by an overly-rich condition, which results in unburned fuel being passed into the exhaust, where it ignites due to heat.
Old Aug 19, 2004 | 06:40 PM
novtecintegra's Avatar
are you sure its a backfire and not a pop from back pressure?
Old Aug 19, 2004 | 07:07 PM
92LsTegra's Avatar
Default Re: (novtecintegra)
mine has the same problem,but mostly when i pull it out of gear when im rolling 20+ mph.i dont know if i have a high flow cat or if its a hollowed out cat either,just bought it a month ago..
Old Aug 20, 2004 | 12:52 PM
luckypon7's Avatar
Default Re: Why is it or Why Does my engine Backfire? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">A backfire is typically caused by an overly-rich condition, which results in unburned fuel being passed into the exhaust, where it ignites due to heat. </TD></TR></TABLE>
i have to agree with this guy. what all did you do to your car?
Old Aug 23, 2004 | 03:49 PM
jdmb20gsr's Avatar
I'm having a similar problem with mine...I'm about to just do the basic "change plugs and wires" to see if it helps at all first.
Old Aug 23, 2004 | 11:43 PM
yeegsr's Avatar
you the man , that is a good way to define backfire man,,,,
*here is some more issure
-backfire can happens when there is no muffler
-highlow cat w/out resonator
-piping is big
backfire happens when there is low backpressure with running fuel ratio is high and air ratior is low....you might want to get bigger CAI to compensate the unburned fuel left over, well to summarize u running over fuel you need more air to get more combustion
backfire ain't bad, some like cuz of its sound...they sound tightass though...
-they can give you 1 or 2 hp as result of pusshing force deduction out...i guess
Old Aug 24, 2004 | 05:06 AM
be.twenty's Avatar
I get pop noises when shifting gears after WOT to redline. Not really loud but noticable.
Old Aug 26, 2004 | 12:59 PM
westspeed's Avatar
bump
Old Aug 26, 2004 | 01:08 PM
Googs16's Avatar
Default Re:
My 94 LS pops at idle and when shifting gears but only the engine warms up,
I need some free time to do some maintenece work
Old Aug 26, 2004 | 01:29 PM
NightRiderS2K's Avatar
In-N-Out Burger
What kind of plugs are you using...
Like that matters. Anyways what size do you gap them at?
Old Aug 26, 2004 | 02:38 PM
vtec69's Avatar
Default Re: (NightRider-gsR)
good info always wondered about this
Old Aug 26, 2004 | 04:00 PM
JDM_Integra1's Avatar
It probably isn't even a backfire it is pop from back pressure. It can be caused by a larger than stock diameter exhaust system. I have an apex-i GT spec on my ls and that pops alot between shifts and when cruising at high rpms
prettylew
Apr 18, 2008 10:08 AM
MADBADGER
Honda S2000
Nov 29, 2007 05:54 PM
shadow29485
Aug 8, 2007 07:00 PM
WTB AUTO EK
Apr 9, 2005 11:24 PM
DOHCon15s
Sep 18, 2003 08:01 AM
