why does my temp go high
hey guys my car temp use to sit at a 1/4 now it sit lil under 1/2....why?....not overheating. http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif
Re: why does my temp go high (JDM.DEEBO)
Your thermostat could be sticking. When was the last time you did maintance on your cooling system?
Just under 1/2 is where it SHOULD be sitting. Have you replaced your thermostat recently? It could have been stuck open and somehow it got un-stuck and is now working properly.
Engines run better and are more efficient when at proper operating temperature. On the water temp gauge, that is just under the 1/2 way mark. |
Re: why does my temp go high (PatrickGSR94)
mine does the same exact thing, im changing my tstat on friday or saturday, ill let you know if it works.
Re: why does my temp go high (TonyRomo)
i thougt it was mine thermostat too....but i just change a brand new one....and still sit at lil under 1/2...it suppose too be a good thing???????? https://honda-tech.com/forums/images...s/emsmileo.gif
could be water pump or temp sensor i have heard. my temp gauge goes way down when i floor it, does yurs do that too?
Mines goes down to when i floor it maybe cause its cold out??
Re: (strtrcr77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strtrcr77 »</TD></TR><TR><TD CLASS="quote">Mines goes down to when i floor it maybe cause its cold out??</TD></TR></TABLE>
nope, could be a lot of things wrong with your cooling system. perhaps a headgasket? It goes down when you floor it because when the engine is under more stress, the water pump will be working harder and thus the coolant circulates faster. |
Re: (alexisthemovie)
what exactly do you think would cause that? acura says nothing is wrong when I know this isnt normal. im goin to change the tstat, but im def not a car guy.
thermostat would be the first thing i do after a compression test to check for a blown headgasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM.DEEBO »</TD></TR><TR><TD CLASS="quote">i thougt it was mine thermostat too....but i just change a brand new one....and still sit at lil under 1/2...it suppose too be a good thing???????? https://honda-tech.com/forums/images...s/emsmileo.gif </TD></TR></TABLE>That's the temperature it's supposed to be at. So if it's just below half way... you're good.
Re: why does my temp go high (Exeed)
lol....ok thanks https://honda-tech.com/forums/images...es/emsmile.gif
Thats where it should be. So you're still good https://honda-tech.com/forums/images/smilies/emthup.gif
