Where's the drain plug for the radiator?
Re: Where's the drain plug for the radiator? (ALMXDUPINTEGRA)
you can not miss it. from looking under the car it is on the right hand side of the radiator. It is white and almost looks like a wing nut.
Re: Where's the drain plug for the radiator? (Ketone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ketone »</TD></TR><TR><TD CLASS="quote">you can not miss it. from looking under the car it is on the right hand side of the radiator. It is white and almost looks like a wing nut.</TD></TR></TABLE>
actually left hand side if youre facing teh car
Re: Where's the drain plug for the radiator? (dvp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvp »</TD></TR><TR><TD CLASS="quote">You've got to be either lazy or joking. Maybe you should get under the car and look. Its right there. </TD></TR></TABLE>
Thanks for your help it was so helpful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional »</TD></TR><TR><TD CLASS="quote">
actually left hand side if youre facing teh car</TD></TR></TABLE>
Thanks
Thanks
actually looking down the left side I didn't see it. By getting under the car..right at the splash guard there is a little opening and the drain plug is right there.
lol jesus.. i answered this question a month ago with pictures of my own raditator and all..
and having a n00b clown on you hahahahahhahaha
goodluck with whatever your trying to do.. probaby flush system
Re: (97tegGS)
Remember to drain the block too, there is quite a bit of coolant in there. It is a big *** bolt (19mm, I think) on the block directly behind your header, if you have a stock manifold you will have to remove the heat shield to get to it, but no flush/coolant change is complete without it.
