Honda S2000 Honda S2000
radiator flushing
Old Aug 28, 2004 | 01:37 PM
JKS2000's Avatar
Default radiator flushing
has anyone done a radiator flush on there s2000? if so how do you do it? is there a bolt like the oil pan on the radiator or do you need to suck it out wit a vacum
Old Aug 28, 2004 | 01:45 PM
evil vapor's Avatar
Default Re: radiator flushing (JKS2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKS2000 &raquo;</TD></TR><TR><TD CLASS="quote">has anyone done a radiator flush on there s2000? if so how do you do it? is there a bolt like the oil pan on the radiator or do you need to suck it out wit a vacum</TD></TR></TABLE>
there's a drain plug on the radiator, not hard to flush, same thing as flushing any other car.
Old Aug 28, 2004 | 01:50 PM
JKS2000's Avatar
Default Re: radiator flushing (vapor)
where is the plug? do i have to take panals off of the car to get to it? and what kinda antifreeze should i use and how much of it do i put in the radiator
Old Aug 28, 2004 | 02:02 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKS2000 &raquo;</TD></TR><TR><TD CLASS="quote">where is the plug? do i have to take panals off of the car to get to it? and what kinda antifreeze should i use and how much of it do i put in the radiator</TD></TR></TABLE>
remove the underpanel plastics, and you can't miss the drain plug, it's white. You can flush the coolant quicker, by removing a coolant hose near the intake manifold and siphoning out the coolant via an extension hose.
Old Aug 28, 2004 | 02:26 PM
Mr. Bagel's Avatar
look in the under the hood forum of s2ki, there's some how-to stickies in there.
b16a4
Sep 5, 2007 05:14 PM
mysicivic1991
Apr 19, 2007 10:57 AM
hks369
Dec 24, 2006 12:43 PM
hondachris1994
17
Apr 9, 2006 07:14 AM
mrlegoman
Welding / Fabrication
Jan 4, 2005 05:39 AM
