where is the pcv?
Old May 4, 2009 | 10:39 PM
turboteg7's Avatar
Default where is the pcv?
ive been having a idle proboblem and i want to check my pcv but i dont know where it is.
Old May 5, 2009 | 12:49 AM
fergs96integra's Avatar
Default Re: where is the pcv?
top of valve cover. Upper center of the cover its just pushed in their. You can remove it without any tools. But if you are having idle problems i would check clean that and also clean the iacv that is bolted to the back of the intake manifold. They are usually the problem.
Old May 5, 2009 | 09:09 AM
HondaHeddie's Avatar
I thought the PCV was in the IM not the valve cover
in fact I just looked at my teg, there are no valves or sensors mounted in the valve cover
there is a breather hose from the air pipe to the vc but the PCV valve is in the intake manifold
Old May 5, 2009 | 11:13 AM
MD426's Avatar
The PCV valve isn't in the valve cover, it's plugged into the IM on the front side of the IM behind the Valve cover.
Old May 5, 2009 | 11:39 AM
sixfourkiller's Avatar
and u really should check your IAC cuz i had that same problem and that was the cause of it
Old May 5, 2009 | 12:06 PM
I meet your IACV
and raise you an FITV
Old May 5, 2009 | 04:48 PM
kronikSLOW's Avatar
i love how everyone on here can tell him where it is or isnt without knowing what engine this kid is running. in fact if he has a 98-01 ls valve cover the pcv valve WILL be on top in the center of the valve cover. with a hose going from the intake manifold to the pcv valve. im tired of the people on this site and their misinformation. ask questions then give answers.
Old May 5, 2009 | 04:51 PM
Uncle Willie's Avatar
Actually on some motors it is. If its an LS B18B the newer ones will have it on the valve cover. If its a gsr b18c1, its a PITA to get at since its buried beneath the IM.
Now i remember why i never come into the Integra section anymore.
Old May 5, 2009 | 04:57 PM
stevenDAtegra's Avatar
I hate it when they are on the im. I always end up breaking them getting them off too
erikiksaz1
Engine Management and Tuning
Sep 25, 2011 09:37 PM
Black R
Jan 25, 2010 07:18 PM
raysjdmh22a
Oct 24, 2006 03:35 PM
Marcos
Apr 12, 2003 06:02 AM
spencer00si
Sep 6, 2002 01:46 PM
