ac not working
Old Apr 16, 2009 | 06:14 PM
GSR936's Avatar
Default ac not working
ok my ac was working fine untill the compressor trun off and wouldnt kick back on. I thought it was old freon so i leak all the freon out and was gonna recharge it. so i tryed to recharge it and it wouldnt take any freon at all. what could it be ?
Old Apr 16, 2009 | 06:39 PM
twentyhurtz's Avatar
Default Re: ac not working
check fuses, man i hate to be abrupt but i dont' think i even know anyone with a honda with a/c anymore, its kinda funny actually, thats why your pretty thin on replys...
Old Apr 16, 2009 | 07:34 PM
j_bizach's Avatar
check ur fuse's if that dont turn up anything id be willing to bet ur compressor is blown. And if that blew u mite as well rip ur a/c out cause replacing a compressor is expensive
Old Apr 17, 2009 | 09:10 AM
GSR936's Avatar
lol they run up to 265 i think at vatozone men this sucks summer is coming up to i better start putting overtime hrs.
Old Apr 17, 2009 | 09:18 AM
dump3deg6's Avatar
Mine did the same thing.. Its not getting signal to the compressor to TURN ON!
So what i did was run a 12 volt source to the plug on the compressor to see if it engauged the clutch.. Thats how I found out that it still works, its just a missing link from the switch to the compressor.
GL!
Old Apr 17, 2009 | 09:25 AM
spklsdb8's Avatar
Many A/C systems have a low-pressure cutout switch that prevents the compressor clutch from engaging if system pressure (the refrigerant charge) is too low.
Old Apr 17, 2009 | 01:40 PM
GSR936's Avatar
i already try to add freon but it wouldnt take it at all.
Old Apr 17, 2009 | 05:23 PM
j_bizach's Avatar
yes autozone sels a/c compressors for 285 but u also need to replace a few parts and flush the system or ull void ur warrenty not to mention potentaly shorten the life of ur new compressor. check ur signal wire to make sure ur getting a signal.
Old May 5, 2009 | 05:25 PM
Frenchy1337's Avatar
GL!
mine just started doing the same thing. Did you find out what the problem was? I wired it to the battery and the compressor kicks in.
drpapijr196
Jun 15, 2011 02:17 PM
SuperCX
Mar 10, 2010 08:18 PM
hmtcrxsir
22
Jul 25, 2008 03:19 PM
