what should i do?
Old Dec 22, 2002 | 01:48 PM
95b18b's Avatar
Default what should i do?
im buying a 95 ls and i was thinkin on what i should do to make it fast. I was thinkin of getting a GSR swap. i was told that a boosted ls would run hard too. And my last result would be to make it an LS/Vtec. which one would run the hardest and which one has the most potential?Thanks
Old Dec 22, 2002 | 01:52 PM
garados's Avatar
Default Re: what should i do? (95b18b)
I would do the SEARCH swap. J/P I would do the turbo setup, just because it has the most bang for the buck. I wouldn't even bother doing the gsr swap or the lsvtec. It's just too much work compared to the turbo setup, and they won't come close to the power output to the turbo.
Old Dec 22, 2002 | 02:13 PM
95b18b's Avatar
Default Re: what should i do? (garados)
i know that an ls boosted would be nice, but if i had enough money to get a GSR swap and boost it, it would run really hard. i heard of a guy who has a GSR who was putting down 18psi and running 11.7s
also, if i totally build a ls motor with pistons, rods, sleeve the block etc, what hp could i expect and what else would be needed to put down the most power while staying non-vtec
Old Dec 22, 2002 | 02:40 PM
Adachi's Avatar
I personally would go b20 first.. then maybe turbo and/or vtec later on.. but just going straight turbo or gsr would always be fun too. Good Luck.
Old Dec 22, 2002 | 03:01 PM
HybriDNA's Avatar
Default Re: what should i do? (Adachi)
Ls/turbo would be best in my opinion. Start saving up and buy a turbo kit. I am have fun with mine. It will be worth it trust me.
Old Dec 22, 2002 | 03:55 PM
H22EK's Avatar
Default Re: what should i do? (10psi)
fawk it all and go with an h22!
Old Dec 22, 2002 | 04:18 PM
Broken Gearbox's Avatar
I think you should turbo it first...then decide if you want a Vtec head or not..
Old Dec 22, 2002 | 04:27 PM
sknot1454's Avatar
Default Re: what should i do? (dEF juNKie)
eh there are a very few ammount of shops that can pull off ls/vtec so that your engine dosent grenade after 5000 miles
FI > LS/vtec
Old Dec 22, 2002 | 05:28 PM
Adachi's Avatar
Default Re: what should i do? (sknot1454)
Okay that's can't be right.. I've done 3 myself in my garage and they dont' even leak oil.
Old Dec 23, 2002 | 12:56 AM
SIK IN DA HED's Avatar
New User
boosted! turbo LS is the way to go.
Old Dec 23, 2002 | 01:21 AM
Type Wah's Avatar
Default Re: what should i do? (dlplayboy)
LS Turbo!! VTEC is not boost, its nice though.. but nothin' can fade Turbo naw mean?
Keenor
Aug 1, 2010 04:51 PM
em1gangsta
Jan 20, 2009 10:48 AM
SIReg9
Jan 15, 2003 11:11 AM
MooreBoost
Oct 17, 2002 10:48 AM
