what engine components are best for lsvtec setup?
Old Mar 12, 2004 | 12:23 PM
RSVTECDC4's Avatar
Default what engine components are best for lsvtec setup?
im planning on doing either one oft he following:
1) swap in b16a into my ls and then build the motor
2) swap the vtec head off the b16a onto my b18b and then swap the pistons into my b18b.
my question is, would the ls block with the b16a vtec head and the b16 pistons be about as fast as a gsr? or nowhere close? i think the b16a pistons have higher compression than the b18b does.. thanx!
Old Mar 12, 2004 | 08:20 PM
dabrown's Avatar
Default Re: what engine components are best for lsvtec setup? (RSVTECDC2)
Hope I can help before the flame.. Try entering in the search engine. " Ls/Vtec" or "LS Vtec". Make sure you select archive.. Good Luck.
Old Mar 12, 2004 | 08:26 PM
mr.beeks's Avatar
Default Re: what engine components are best for lsvtec setup? (dabrown)
if you have to ask...
I think LSVTEC is for a more knowledgeable guy..
not to offend you but
everybody has a different combinations for this set up
so do your homework and choose your set up...
http://www.importbuilders.com
http://www.c-speedracing.com
http://www.theoldone.com
Kendall's Avatar
Are your B16A pistons PR3 or P30? Either way, it will help the engine to make more power. The stock rods should work, but I'd look at upgrading to some Eagle's. It would be a very good idea to have the crank balanced and then have the pistons checked for correct balance before you use them. I think you should be able to take a GSR. Hell, an LS with just the P30 pistons and some other minor mods should be able to pull a stock GSR.
Old Mar 12, 2004 | 08:46 PM
W.O.P.'s Avatar
Default Re: (Kendall)
your screen name is rsvtecdc2 and its not even vtec? why. hope you know you have a dc4 not a dc2 the dc4 is non-vtec i.e. ls/RS/gs. just so you know. also search the ARCHIVED forums about this you will find hunderds of posts just like yours. most arent informative as we are tired of seeing this crap and just flame but you might find something
97dxswap
Nov 17, 2004 08:21 PM
Skyllz
Mar 28, 2003 02:55 PM
hahahahhah
22
Jan 14, 2003 06:21 AM
91redintegra
Jan 6, 2003 05:57 PM
ckkl
Apr 8, 2002 03:39 AM
