weird electrical problem
Old May 16, 2007 | 08:23 PM
NA JDM GSR's Avatar
Default weird electrical problem
my corner lights and taillights turn on automatically when i connect the negative back on the battery becaus ei was changin my dash from tan to black...my lights are set as off but their always on...i cant turn them off unless i disconnect the negative...and my headlights wont turn on even if i switch them on
Old May 17, 2007 | 07:52 AM
NA JDM GSR's Avatar
Default Re: weird electrical problem (NA JDM GSR)
Old May 17, 2007 | 10:26 AM
Code's Avatar
Not now Chief, I'm in the F'n zone!
You've got a short somewhere.
Old May 17, 2007 | 12:25 PM
NA JDM GSR's Avatar
Default Re: weird electrical problem (Code)
where should i check?
Old May 17, 2007 | 01:48 PM
mc-integra111's Avatar
Check for a bad ground. Maybe in the process of changing over the dash you forgot to connect a ground wire, or maybe the ground wire was re-connected in a new location that is not providing a good connection.
Old May 30, 2007 | 02:53 PM
NA JDM GSR's Avatar
Default Re: weird electrical problem (mc-integra111)
grounds are good
Old May 30, 2007 | 05:53 PM
NA JDM GSR's Avatar
Grumpy pigeon
Honda Civic (2001 - 2005)
Apr 24, 2017 07:44 AM
jordan reynolds
Aug 24, 2010 09:39 PM
91integraLSVTEC
Apr 9, 2009 10:40 AM
SiYouLater
Mar 15, 2009 03:53 PM
R91Si
Oct 11, 2002 08:24 AM
