weird battery problem!
Old May 22, 2006 | 06:47 PM
caliek4's Avatar
Default weird battery problem!
i have a 91 LS and this winter for some reason the car wasnt starting. i changed the battery and tested to make sure it wasnt the alternator. after changing the battery it would still die and have to be jump started. after a while it went away and the car started up fine. well yesterday it rained and for some reason the car didnt start. i think that it has something to do with the rain. does anyone have experiance with this???
Old May 22, 2006 | 07:06 PM
InfamousDC2FI's Avatar
Default Re: weird battery problem! (caliek4)
Did you test the battery?? check your connections to your starter....sometimes that little starter signal wire will come loose
Old May 22, 2006 | 07:10 PM
caliek4's Avatar
Default Re: weird battery problem! (InfamousDC2FI)
would that have anything to do with the rain?? it only seems to die when it rains??
Old May 22, 2006 | 07:28 PM
the rain could cause moisture to interrupt connections...
Old May 22, 2006 | 09:37 PM
caliek4's Avatar
so which wire should i check on the starter?
Old May 23, 2006 | 07:31 AM
check all the connections on the starter including the battery terminals. It could be that your battery terminals are dirty with corosion.
Old May 23, 2006 | 07:45 AM
stepka001's Avatar
Try to replace the Distributor cap with a oem one
Old May 23, 2006 | 01:14 PM
caliek4's Avatar
Default Re: (stepka001)
bump
Old May 23, 2006 | 04:00 PM
caliek4's Avatar
Default Re: (caliek4)
bump
Old May 23, 2006 | 11:06 PM
caliek4's Avatar
bump
Old May 24, 2006 | 10:04 AM
caliek4's Avatar
so should i change the distributor cap?
Old May 24, 2006 | 11:46 AM
wait....does it even turn over when you try to start it?? If not then rule out the distributor cap for the time being.... did you check your connections like i said before? You need to clean the battery connections with some battery acid cleaner and a brush....
do you have a camera??
Old May 24, 2006 | 12:49 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (InfamousDC2FI)
If it turns over but will not start when it rains (high humidity) then the problem is definitely in your distributor. I've heard of it happening on a number of different makes and models of cars.
Old May 24, 2006 | 02:59 PM
stepka001's Avatar
Just make shure you go to Honda to get one, While your there replace the rotor as well.
Old May 26, 2006 | 08:11 AM
caliek4's Avatar
so i check the battery and the battery had no corrosion and had a good connection and the starter is ok. i also check the distributer by pulling out one of the spark wires and putting it to a ground. i saw the spark jump. it look kinda weak though. could it still be the distributor. it does crank over but dosent want to start. i was also told to look at the fuel pump to make sure that it was getting fuel. is there anything else i could check?
Old May 26, 2006 | 11:44 PM
caliek4's Avatar
bump
Old May 29, 2006 | 06:04 AM
stepka001's Avatar
Dude, Replace your cap and rotor!!!!!
Old May 29, 2006 | 11:23 AM
caliek4's Avatar
thank you finally
Integ808
Oct 16, 2008 02:57 AM
SiB16A
Jun 11, 2006 12:37 PM
B18 CYA
Oct 29, 2004 07:59 PM
GsR HtCh
Mar 2, 2004 08:12 AM
J^M^
Audio / Security / Video
Aug 8, 2003 01:27 PM
