cap for starter?!
Old Aug 6, 2003 | 01:33 AM
J^M^'s Avatar
Default cap for starter?!
ok, whenever i bump too long the battery goes low ad the starter won't turn over, instead of upgrading battery i thought i'd pop a cap on the 4awg starter to battery wire, so i'd have juice to start the car....
good idea?
Old Aug 6, 2003 | 05:37 AM
PupaScoopa's Avatar
Default Re: cap for starter?! (mad_max)
Nope, the cap will drain when the battery does. If you leave a charged capacitor sitting for an hour, it will drain significantly.
Old Aug 6, 2003 | 08:56 AM
J^M^'s Avatar
bitch!
Old Aug 7, 2003 | 09:30 AM
tegmech's Avatar
nope....the cap would help but you need to run it inline on the power wire to the amp. and how much power are you running? (1/2 farad per 500 watts.) Do that and you will be fine.
Old Aug 8, 2003 | 08:45 AM
PupaScoopa's Avatar
Default Re: (tegmech)
Hows it going to help with voltage is 10vdc or less... the battery is dead.
Old Aug 8, 2003 | 09:14 AM
rjr162's Avatar
Default Re: (PupaScoopa)
it would help very little. My guess is your battery is old and shot, and you'd need a huge bank of caps to make up for that. Just get yourself a new battery. You might also want to check your alternator just to make sure it's not going out itself
Old Aug 8, 2003 | 01:27 PM
J^M^'s Avatar
thanks, actually my alt is hit, ill replace with a bigger one and see, battery is new
Dontoh
Aug 9, 2011 08:19 PM
Flexin5
Audio / Security / Video
Jul 19, 2007 07:38 PM
'90crxSI
10
Sep 28, 2006 05:23 PM
Honduh Chicken
17
Mar 9, 2005 08:14 PM
sleepin91teg
May 29, 2004 11:53 AM
