WEIRD ACCELERATION WHILE DRIVING!!!! HELP PLEASE!!!
Old Aug 27, 2014 | 12:16 PM
Teggy_Newb428's Avatar
Default WEIRD ACCELERATION WHILE DRIVING!!!! HELP PLEASE!!!
Hello Fellow Teggy Funatics, I have 1996 Acura Integra LS Coupe bone stock, but the transmission is to 1997 Acura Integra LS Sedan. weird huh? lol
Ok, so the Problem is, (And Let me tell you its tough to explain and hopefully it gives you an idea of whats goin on.)
- I turn the key and wait for the Fuel Pump to engage and then I turn the car on.(It starts like a champ no problem)
- It'll idle up high to around 2000rpms and slowly comes down as it warms up.(I let it warm up for about 5-7 minutes until temp gauge starts to move)
- it'll drive normal out the driveway, BUT ONCE I come up to the next street light and stop. it'll idle real low to about 100-300pms, Point of Bogging Out.(PBO)
- When I take off is the Shitty part because as I take off, I slowly give it more gas as normal but then it'll slow down/die down while giving gas, like if the more I give it gas the more it slows down/die down or it'll stay stuff at a certain rpm for like a minute or so and then it'll shift into its next gear. Sometimes its a Rough Shift, and sometimes its like I have a stage 3 clutch quick.???? IDK, its weird i know, but hopefully, you guys understand me, if not ask questions please and DON'T BE DICK ABOUT IT,
Old Aug 28, 2014 | 08:36 AM
tamboo's Avatar
10 Year Member
Default Re: WEIRD ACCELERATION WHILE DRIVING!!!! HELP PLEASE!!!
check your cams/crank alignment at tdc, test ignition stuff and tps.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/official-honda-tps-wiring-calibration-thread-2830131/
http://www.team-integra.net/forum/bl...eshooting.html
Kirk@SyndromeAuto
Jan 31, 2007 08:45 PM
pbizzlegsr
Mar 13, 2004 01:04 AM
uszcrx
19
Jun 19, 2003 04:27 AM
Boost2NA
Sep 10, 2002 02:33 AM
