weird acceleration problem. no cel, need help!
Old Jul 28, 2008 | 05:08 PM
integra82786's Avatar
Default weird acceleration problem. no cel, need help!
I've found a bunch of threads that come close to the same issue I'm having, but from my experience with cars a little difference in diagnosis can make a huge difference on what the solution may be. I drive a 95 integra gsr that has a jdm gsr swap in it. I bought the swap about 8 months ago when my old set up died on me. I'm guessing the jdm swap has around 75k miles on it now since I've put about 20k on it personally. I put the motor in and all was well up until about 2 weeks ago.
The issue is, when the car warms up to it's regular operating temperature it starts to run very sluggish and weak, and I have a fluttering noise which I can't differentiate between a timing belt flap or an exhaust leak. I have replaced the fuel filter, cleaned the k&n, checked fluid levels, spark plugs, wires, etc for problems. all seem to be ok. From what the other threads have posted it seems like it may either be a distributor or a timing issue, and I am due for a belt, tensioner and water pump. I have a new distributor to put on it to see if that's the problem. I just really want to make sure it isn't a compression or misfire issue. Any and all help is appreciated, thanks to anyone with legitimate advice.
Old Jul 28, 2008 | 05:41 PM
herewegoagain's Avatar
personally i would remove the valve cover and feel the tensionon of the belt. you could try putting a 12mm wrench on the intake cam sprocket and rotate counter clockwise. if it moves without moving the exhaust cam the tensioner may be shot, or just mis-adjusted. now when i say rotate, i dont mean rotate completely, i mean just a little. if you see slack between the intake cam and the exhaust cam, sorta on top of the cams, sounds like the tensioner to me.
Old Jul 28, 2008 | 05:50 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: (herewegoagain)
Did you reset the ecu? I would replace the dizzy. cap and rotor and reset the ecu!
Old Jul 29, 2008 | 02:26 PM
yeah, I put type r cams in a little while ago and had reset the ecu then so that the fuel trim could readjust itself. and as far as the tensioner, I may not have tightened down enough or something. I just figured it would have shown symptoms right then. Something I noticed when driving today though, the car heated up to operating temperature and it didn't start getting sluggish until I had to kinda stomp it to get into traffic. After that I noticed it instantly start running bad. Replacing the dizzy today though so we'll see if thats the problem. will check the belt as well for tension.
jshaw23
Feb 25, 2009 05:45 AM
pacifico
Aug 28, 2004 08:37 PM
NatedoggAZ
May 26, 2004 05:20 PM
dc2inms
Oct 9, 2003 01:33 AM
SpyderZEX
19
Aug 5, 2003 02:42 PM
