jdm h22 hesitation
jdm h22 hesitation
I have a 1997 honda civic with a jdm h22 swap. It has been in my car now for about 4 months and i have yet to figure out what is causing my hesitation. The hesitation happens around 3000 rpm and stops around 4300 or so and then it pulls hard once again. Before doing the swap i replaced cap, rotor, plugs, plug wires, timing belt. Timing i had checked at a shop to make sure it was good. So what else can i check to figure out what the hell my problem is. Thanks in advance for any help.
Re: jdm h22 hesitation
Me and a couple buddies did a h swap on my friends eg. We got the same problem. Everything was replaced and we even went ahead and rewired again, same result. To be honest, your best bet is taking it to a expert. It is going to cost you a hand full though. They feel since you didn't come to them in the first place they are still going to make money off of you.(by charging the check out of you just to find the problem) Also they didn't do none of the work. So they have to start from the begin which is a long process. Your choice you can either keep on trying to fix it or take it to a shop and get it done a.s.a.p.
