vtec problem?
Old Feb 25, 2010 | 08:58 PM
DrewBrews's Avatar
Default vtec problem?
I have a stock gsr with just intake and i was wondering how do i know if my vtec is working? aren't you suppose to hear it kick in around 5k rpm? because i don't. So what are the things that i have to check or to know that it is working properly?
Old Feb 25, 2010 | 09:00 PM
GagnarTheUnruly's Avatar
Default Re: vtec problem?
If you can rev above 6000 rpm in any gear, VTEC is working. You can't really hear VTEC on a stock GSR and you aren't supposed to feel it.
Old Feb 26, 2010 | 05:09 AM
adamrich33's Avatar
with just a cold air intake, stock intake manifold and exhaust, it is hard to hear, but you can hear. if the car is warm, you have good oil psi and no CEL's run through 2 or 3rd gear at half throttle and listen very closely and you should hear it engage around 5k. this is how i kept mine in check until i went with, skunk2 IM, turbo and 3in exhaust, now its very noticeable.
Old Feb 26, 2010 | 05:46 AM
dpetro1's Avatar
stock gsr vtec is set pretty low making it harder to hear and as mentioned above pretty tough to hear with stock IM and exhaust anyways
double check that your oil level is correct (vtec needs the correct oil pressure to engage) and make sure you do not have any CEL for vtec components
Last edited by dpetro1; Feb 26, 2010 at 09:17 AM. Reason: incorrect vtec and iab rpm
Old Feb 26, 2010 | 06:27 AM
OH_1fstgsr's Avatar
VTEC is 4400
IAB is 5650
In a stock GSR you shouldn't feel it or hear it.
Even in a modified car you should only hear it, with a good tune you won't feel it.
Old Feb 26, 2010 | 06:49 AM
95 integra's Avatar
Oh noes with the bad information and yes, vtec is at 4400 and secondaries are at 5950ish (as I recall this is a variable number and can vary up to 200rpms either direction).
Old Feb 26, 2010 | 06:58 AM
DrewBrews's Avatar
alright thanks but how do i check and know if the oil pressure is correct and what is CEL? sorry noob here.
Old Feb 26, 2010 | 07:07 AM
To check oil level you just use the dipstick. In case you don't know how to do that: when the engine is warm, but off, remove the dipstick (between header runners), wipe it with a rag, re-insert it and remove it again. Oil level should be between the two marks.
To check pressure you need to install an oil pressure gauge, but you probably don't have a pressure problem unless you're seriously low on oil.
CEL = 'Check Engine Light' It lights up when the ship's computer detects a malfunction in one of the monitored systems. If there's a problem the CEL lights up in the gauge cluster and the computer begins reporting an error code. You can use a trick to read the code yourself, or take it to a mechanic who will plug into the computer and read the code off of the computer. The code tells you specifically what caused the CEL to illuminate. If VTEC isn't working you'll get a CEL.
You can see the CEL illuminate when you start the car -- it's a diagnostic procedure to let you know that the light is working. If it stays on once the car is running then you know the ECU (the computer) is reporting a problem.
Old Feb 26, 2010 | 07:11 AM
sho_shane's Avatar
lol this is a doush post.
Old Feb 26, 2010 | 07:31 AM
95 integra's Avatar
I hate newbs.
Old Feb 26, 2010 | 07:43 AM
LOL I hope it wasn't too douchey. I was actually just trying to help -- hopefully the OP won't be offended.
sebTeggy
Feb 22, 2012 10:21 PM
Inaccurate
Jun 14, 2009 09:41 PM
EFboosted
Oct 14, 2008 01:18 PM
xstalkrx
Oct 13, 2003 06:10 PM
vietshinobi
Oct 14, 2002 08:45 AM
