vtec problem
Old Sep 13, 2007 | 03:04 PM
racereaper7's Avatar
Default vtec problem
my car is throwing a check engine light 22 which is the vtec pressure valve does anyone know how to fix this and if this would be a reason why my vtec is not working. is there any other reasons that you can think of that would not allow the vtec to kick in. would buying a new vtec solinoid would fix the whole thing. if so does anyone know a site that sells a vtec solinod for a jdm b16a second gen. any help would be great thanks in advance.
Old Sep 13, 2007 | 03:55 PM
Default Re: vtec problem (racereaper7)
my engine is a jdm b16a second gen in a 95 integra ls
Old Sep 13, 2007 | 03:58 PM
c1_sleeper's Avatar
ur prolly low on oil.. try topping it off.. theres is also a screen between the vtec solenoid and head.. try taking it out and cleaning it if it is clogged
Old Sep 13, 2007 | 04:02 PM
Brian2.0's Avatar
Default Re: vtec problem (c1_sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1_sleeper &raquo;</TD></TR><TR><TD CLASS="quote">theres is also a screen between the vtec solenoid and head.. try taking it out and cleaning it if it is clogged</TD></TR></TABLE>
X2 common problem.
Old Sep 13, 2007 | 04:27 PM
you would not have a picture or a diagram by any chance. will any way if you do or dont thanks for the help.
Old Sep 14, 2007 | 08:09 AM
TIMMY4TOES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racereaper7 &raquo;</TD></TR><TR><TD CLASS="quote">you would not have a picture or a diagram by any chance. will any way if you do or dont thanks for the help.</TD></TR></TABLE>
visual diagram,
its next to the distributor on the side of the cyclinder head remove two bolts holding it and clean, repeat if neccessary
Old Sep 14, 2007 | 08:10 AM
TIMMY4TOES's Avatar
if your vtec is not working and is throwing a vtec code then most this is causing.
simple detective skills.
Old Sep 14, 2007 | 11:16 AM
MadVtak's Avatar
* B A N N E D *
From: Biggest Baddest Little City in The World RENO, NV
VTEC WILL NOT ENGAGE WITH A CEL. ALSO YEAH JUST TAKE THE SOLENOID OF OF THE HEAD, CLEAN THE SCREEN, THERE IS ANOTHER SCREEN IN THE TOP PART WHERE THE ACTUAL SOLENOID IS (THE ROUND THING ON TOP , JUST TAKE THE BOLTS OUT)
Old Sep 14, 2007 | 04:26 PM
Default Re: (MadVtak)
this sounds like a stupid question but what does the screen look like. is it the rubber grommet? i took the vtec solenoid off the head of the engine and where is the screen. im sorry for asking this stupid question. i took the top part of the solenoid and there was a rubber grommet there thats where i thought the screen was a grommet. thanks for the help so far.
Old Sep 14, 2007 | 06:40 PM
what engine is this from? mine looks different than the one in this picture.
Old Sep 14, 2007 | 06:46 PM
doood's Avatar
been there done that
jdm engines do not have a vtec pressure switch. if you're using a usdm ecu it will look for this switch, which isnt there, which would set off the CEL. dos your's look like this?
easy fix: https://honda-tech.com/zerothread/1693528
Old Sep 14, 2007 | 06:54 PM
Default Re: vtec problem (doood)
thanks for your help thats what my vtec sol. looks like. ill take a look at the link and let you know if it works. thanks again.
Old Sep 14, 2007 | 06:55 PM
doood's Avatar
are you using a usdm ecu though?
Old Sep 14, 2007 | 09:28 PM
XSIintegra's Avatar
don't quote me..but i believe I ran into the same problem with a USDM ECU. I ran the wire back behind the block and tapped into a oil pressure sensor on the back of the block.
(it was 2 years ago...so i may be off..but I believe that solved the problem)
Old Sep 15, 2007 | 04:00 AM
yes i am using usdm ecu. i had it skunk2/spoon tuned thinking it would fix a past problem.
Old Sep 15, 2007 | 01:10 PM
with the link that was posted "so your sayin hook a4 and d6 together then run it to the vtec solenoid ??" is this all i have to do?
Old Sep 15, 2007 | 04:50 PM
now i have another question. i did an engine swap and this might be a reason why it is messing up. i have a 95 integra ls with a jdm b16a sec gen engine. and usdm ecu, and the engine wiring harness is the ls wiring harness because the other harness that came with the engine was cut to pieces. i found a site that shows how to wire in the vtec. these are the wires that i have attached and there pins. pin a4 to the vtec solenoid, pin d6 to the vtec oil pressure sensor(which i dont have so that is the problem. it goes into a clip with another wire that is a ground.) then d3 goes into knock sensor. then there is also a wire attached to the pin d6 for the ground as i said before. with the site that was given to me said to " i just cut the a4 and d6 wires on the connector and solder them together and this will give me my missing vtec. is it really that simple?" im i suppose to take pin a4 and d6 twist them together and attach them to one wire that goes into the vtec solenoid? and what do i do with the wire that goes with the ground which goes to the "vtec oil pressure sensor"? i dont know what to do.
this is a link of the picture that im using because i dont know how to insert a picture on to this site.
http://www.hondaforums.com/lof....html
i dont know what to do know. i REALLY need help. please any and all help would help me a lot.
Old Sep 15, 2007 | 05:55 PM
or should i just take it to the honda dealership to see if they can fix it or if they would even be willing to do it
Old Sep 16, 2007 | 03:26 AM
i just need a little more help and i think i got it
Old Sep 16, 2007 | 08:16 AM
XSIintegra's Avatar
I think the two wires your soldering together does exactly what I have done in the past. Running the Vtec pressure sensor wire to the back of the block was probably just the same as you soldering A4 and B6 together.
Let us know if it works
Old Sep 16, 2007 | 05:32 PM
Default Re: vtec problem (XSIintegra)
i did the whole soldering of the wires and the cel turned off. thanks for all your help everyone.
Fastwhip
Aug 2, 2007 03:58 PM
94HONDAHEAD
15
Jun 3, 2007 10:50 AM
MrRealityman
Apr 28, 2006 08:16 AM
allmotor94hatch
Aug 30, 2005 06:34 AM
lmiguelvv
Oct 19, 2004 06:55 PM
