VTEC light
Old Jul 9, 2002 | 08:34 PM
Aaron M's Avatar
Default VTEC light
Would it be possible to use the VTEC signal wire on the ecu to hook up a LED to go on when VTEC is engaged? Just wondering, I'm kinda bored and I want something cheap/fun/easy to do. I feel depressed when I don't work on my car.
Old Jul 9, 2002 | 08:46 PM
eargrub's Avatar
Default Re: VTEC light (SilverB18C1)
i was wondering the same thing, but i was also wanting to know why my 97 gsr doesn't even have the vtec light???
Old Jul 9, 2002 | 08:48 PM
threatcon13's Avatar
New User
Default Re: VTEC light (eargrub)
what do u mean doesn't "have" the vtec light??? and yes you can splice off that wire to make an LED...some bastards sell instructions on ebay for like ten bucks..but i know that people on here have done it before.
Old Jul 9, 2002 | 09:11 PM
bocian's Avatar
yea im admit i had done it...i was a ricer, i had the vtec light light up everytime i hit vtec. i got the light for a couple bucks when gettin my ww kit. what the hell, it wasnt that bad but its off now. theres a wire that you splice in the passenger side panel by the floor mat. its simple but i forgot which wire it is.
[Modified by bocian, 1:12 AM 7/10/2002]
Old Jul 9, 2002 | 09:16 PM
bboychris's Avatar
seen it done on si's not sure about integras but i beleive so
Old Jul 9, 2002 | 09:18 PM
Aaron M's Avatar
Default Re: VTEC light (vteckid)
http://jdmfan.com/technical/cosmetic/vtec_indicator/
will this work for integra?
Old Jul 9, 2002 | 09:29 PM
PnX-R's Avatar
I've got exactly what you're talking about.. But the weird thing is that it only lights up when the secondaries come in.. Not sure if that's what it's suppose to do or not.. But yeah, you can hear VTEC and see the light go on.. I still remember how to do it So if you're interested, let me know.. It's very easy.. Later....
Old Jul 9, 2002 | 09:31 PM
Aaron M's Avatar
Default Re: VTEC light (PnX-R)
could you post it? im sure it will help many others
Old Jul 9, 2002 | 11:09 PM
PnX-R's Avatar
Well what I did was a little different. I got the idea from "pgthao".. All I did was I looked for the VTEC Solenoid and unplugged it in the engine bay. Next I looked for the colored wire that goes from the solenoid to the ECU. Then I matched the wires and spliced into it. From there I bought a 6V bulb from the radioshack along with the piece that it screws onto. Next I ran the wiring so that it would go underneath the glove department in the center console and through the sliding spot for the fan switch. I left it sitting there. And from there on, whenever I hit the secondaries, it brighter than m*tha at night.. Lights up the whole car.. Hope that helps.. Later..
Old Jul 10, 2002 | 12:29 AM
DSayavan's Avatar
Check this out, it lists the part #'s from Radio Shack. I already made it, I've just got to put it in now. These are instructions for a Civic SI, but I'm told that the VTEC wire is the same color on Integras. Hope this helps. http://www.hazone.com/default.htm?howto/mtrmount.htm
Old Jul 10, 2002 | 04:25 AM
Asahi's Avatar
Default Re: VTEC light (DSayavan)
VTEC wire at the ECU is a John Deer wire (Green w/Yellow stripe)
Old Jul 10, 2002 | 06:48 AM
Aaron M's Avatar
Default Re: VTEC light (Asahi)
if i use a 12v LED do i still need to use resistors or no? and is the vtec wire the same for ODBI and ODBII?
Old Jul 10, 2002 | 07:38 AM
GSR-REX's Avatar
New User
Good question I have OBDI.
Also...does it turn on when the secondaries hit or when VTEC engages? I'd rather have it when the secondaries open up becasue the extra noise coupled with the light coming on would be pretty neat I think...
Old Jul 10, 2002 | 08:46 AM
Aaron M's Avatar
Default Re: VTEC light (GSR-REX)
from what iv read i think it comes on when secondaries open ~5700rpm
Old Jul 10, 2002 | 08:50 AM
Asahi's Avatar
does that really make sense? Connect it to the wire for the VTEC solenoid and you get the light when the secondary intake rnner solenoid switches?
Most likely someone is confusing the 2 solenoids on the install
Old Jul 10, 2002 | 12:07 PM
Aaron M's Avatar
cant u just ocnnect it to the ecu wire?
Old Jul 10, 2002 | 12:15 PM
GSR-REX's Avatar
New User
I'm just interested in which wire carries the current that will turn on the light when the secondaries kick in. If anybody knows....I'd love to find out! Then I can just follow the rest of the instructions.
Old Jul 10, 2002 | 12:37 PM
B-Series Sol's Avatar
JDMfan.com has explicit directions. If you know which wire on the ECU is the one for the VTEC selenoid, im sure that you can splice that one. I highly suggest tapping the wire on the VTEC selenoid if u must do this... simply because the less u chop into the ECU wires, the better.
Also, i believe there was a reason to splice the wire entirely, not just tap it... but im not sure. check JDMFan.com
I dont think u need a VTEC light though... kinda goofy.
Old Jul 10, 2002 | 01:22 PM
GetawayInMoscow's Avatar
Default Re: VTEC light (B-Series Sol)
Will this work on Intrgra LSes too?
Note: I'm just kidding.
Old Jul 10, 2002 | 03:49 PM
Aaron M's Avatar
Default Re: VTEC light (GetawayinMoscow)
my only concern is what is the voltage comeing out of the vtec signal wire. because i need to know what kind of LED to get. will a 12 volt LED work?
anybody?
Old Jul 10, 2002 | 03:54 PM
LS-VTEC 101
Actually I found out a new way to do the LS-VTEC conversion...
1. Forget about the whole VTEC head thing.. highly over rated.
2. Attach a wire to your ECU, and tag it "VTEC Light"
3. Put an LED on your dash, and put some masking tape next to it. that says "VTEC"
4. Then wire the LED to the ECU and a Microwave Oven..
Now, you saved urself 1500 bucks... and when the VTEC kicks in the light comes on and there is a nice "ding!" to let you know ur VTEC is working...
Old Jul 10, 2002 | 03:59 PM
Aaron M's Avatar
Old Jul 10, 2002 | 09:13 PM
PnX-R's Avatar
My light goes on when the secondaries open up..
Old Jul 10, 2002 | 09:16 PM
PnX-R's Avatar
What??.. There's 2 Solenoids??.. Let me know when find the other one..
Old Jul 10, 2002 | 09:23 PM
Aaron M's Avatar
so how did u make your light?
