VTEC Don't work
Old Jan 3, 2011 | 02:57 PM
thunderboy's Avatar
Default VTEC Don't work
Hi i have a integra GSR B18C and my vtec stop working. what can be the problem?? What do i have to check to put it work again?? HELP PLEASE
Old Jan 3, 2011 | 03:23 PM
dntnedvtec's Avatar
Default Re: VTEC Don't work
Any check engine codes?
Old Jan 3, 2011 | 03:38 PM
1998GsRIntegra's Avatar
Do you have any oil leaks on the motor? If so, could be causing enough of a drop in oil pressure for vtec to not work.
Check your oil and make sure its not low as well.
Old Jan 3, 2011 | 05:10 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old Jan 3, 2011 | 08:27 PM
Jimmy's Avatar
Global Moderator
Originally Posted by HondaPartsHero
Old Jan 3, 2011 | 08:29 PM
Jimmy's Avatar
Global Moderator
Added that link to the faq.
Old Jan 6, 2011 | 06:30 AM
thunderboy's Avatar
i got code 21
Old Jan 6, 2011 | 07:02 AM
jdm-style-dc2's Avatar
code 21 = VTEC solenoid
You can try to change it. or just chang the oil pressure switch also if its a swap make sure the yellow/green wire is wired up correctly from the VTEC solenoid all the way to your ecu.Also make sure your not low in oil.
BTW vtec wouldnt work if the car is too cold drive it of a lil and check i it works.
GOOD LUCK
Old Jan 6, 2011 | 10:13 AM
DrzFinestTeggy3's Avatar
g/l finding information, if its your vtec solenoid, try the plug, wiring or replacing the top piece.
94wip
12
Jun 20, 2024 07:23 PM
Ej1Scruggs
Sep 1, 2010 11:41 AM
danteisme
Sep 26, 2004 03:19 PM
Hondasaurs
May 9, 2003 08:51 PM
spoonef
Feb 28, 2003 10:01 AM
