Vtec checklist.
Old Oct 31, 2008 | 08:07 PM
RSX2SIcivic's Avatar
Default Vtec checklist.
I have an 01 GSR, my vtec isnt working. Can anyone tell me what are the things to check for when checking why vtec doesnt work. My speedometer isnt working either, does that affect it at all?
Old Oct 31, 2008 | 08:10 PM
majinsoftware's Avatar
yep speed needs to be above 20ks for vtec to work.
Old Oct 31, 2008 | 08:31 PM
Default Re: Vtec checklist. (RSX2SIcivic)
K but my RPM's, gas, engine temp gauge are all working. Its just the Speed, the MPHs that doent work. Im gonna try an fix that now, if that doesnt do it wat else do i look for? Is there a complete list of things or what?
Old Oct 31, 2008 | 08:55 PM
It will be the speed, ecu checks:
engine temp
speed
oil pressure (some ecus)
rpm
Had the speedo cable come out on my car while I was racing. That was fun no more vtec.
When you get your speedo working if it still doesn't work check oil level and thats its clean.
Then run a wire to the solinoid with a led/light grounded. The led should light up when your going fast enough and your cars warmed up.
Run the cable to the inside of your car or jack it up and test on the spot.
If the light comes on but vtec doesn't engage then it will be your solenoid or oil is too dirty to engage it.
If it doesnt your going to have problems trying to track it down. Try all those then post back so I dont have to list every other problem it could be.
Old Nov 1, 2008 | 11:56 AM
b17rider's Avatar
your speedo has to work inorder for vtec to work
dointhemzs
Nov 20, 2008 03:44 PM
mtg4gen
May 13, 2007 06:14 AM
GsrTurboCRX88
Sep 21, 2006 06:43 PM
civicseth
16
May 18, 2005 08:51 PM
blykins
Oct 30, 2001 10:50 PM
