Vtec Adjustment
Old Apr 9, 2007 | 09:43 AM
IOWAb16TEG's Avatar
Default Vtec Adjustment
I have a b16 in my 91 GS and the guy who I bought it from somehow set the vtec to engage at 4200, this is to low. Ive been told that vtec robs torque on the low end. Is there a way to adjust it higher, say 5500. Can I do this manually or do I need a controller.
Old Apr 9, 2007 | 10:30 AM
jdmbwoy's Avatar
Default Re: Vtec Adjustment (IOWAb16TEG)
damn....you sayin that makes me wonder if mines is too low, and mines comes in at 5 grand, but i was told just to get a v tec controller...unless you know someone who can tune your computer.
Old Apr 9, 2007 | 11:14 AM
doood's Avatar
been there done that
Default Re: Vtec Adjustment (jdmbwoy)
is the ecu chipped?
Old Apr 9, 2007 | 11:36 AM
PLAGUED_DB7's Avatar
Default Re: Vtec Adjustment (doood)
Vtec Controller
Old Apr 9, 2007 | 07:13 PM
IOWAb16TEG's Avatar
the ecu is not chipped. Also ive looked at a few vtec controllers, The Vcon by buddy club (cheap route) and the vafc from APEXi. does anyone know if the vcon is any good and could a non profeccional wire it up themselves.
Old Apr 9, 2007 | 09:36 PM
iMissMyHOME808's Avatar
well if your looking into "only" adjusting your vtec...then just go with the buddy club vconn. also the vconn is user's friendly..by the twist of the **** you can easily adjust your vtec engagnement as oppose to the apexi which requires more technical adjustments which is a bit more complicated.
Old Apr 10, 2007 | 01:48 AM
tomlinson619's Avatar
Default Re: Vtec Adjustment (iMissMyHOME808)
is your ecu stock or what??? u probably using a wrong ECU.. other than that.. get a VAFC, a bone stock ECU, or a chipped ECU /thread
Old Apr 10, 2007 | 06:28 AM
IOWAb16TEG's Avatar
my ECU is OEM
Old Apr 10, 2007 | 01:09 PM
doood's Avatar
Default Re: (IOWAb16TEG)
i dont see how your vtec x-over can be that low if you're using a stock ecu. it has to be chipped or you're using the wrong one.
Old Apr 11, 2007 | 05:47 AM
IOWAb16TEG's Avatar
i see what your saying here. Im not to good with ecu ****. Im not shure what ecu im using really. As far as im aware of there are not vtec engines that engage at 4200. So maby it is chipped. How can I tell?
Old Apr 11, 2007 | 02:18 PM
JDM_EK4_Coupe's Avatar
(banned)
What kind of ECU are you running? (P28, P30, P72?)
blacktibby07
Jun 8, 2011 07:11 AM
ExCiViChYbRiD
Oct 20, 2007 07:14 AM
cookci
Apr 6, 2004 01:24 AM
[626] SiRJKwIcK89Ef
27
Oct 10, 2001 03:33 PM
[626] SiRJKwIcK89Ef
Oct 10, 2001 06:37 AM
