Very weird noise coming from intake
Old 02-06-2016, 07:49 PM
potatointegra01's Avatar
Default Very weird noise coming from intake
So it's a b20b motor with a ls intake. The swap was just recently done but when the car starts or idles or even sometimes moving it sounds like a geese is stuck in the intake manifold I mean it's loud.
It's not the regular after market intake sound either. Not even a tuner shop heard of it before.
It sound like a starter is going off basically, but it's not the starter. And it gets even weirder I will pull the intake out and block the air flow to the engine with my hand and it doesn't shut off.
The noise sometimes gets to a point where it's louder than my car and I have a 3inch straight pipe.
Any solutions or suggestions would be great.
Old 02-09-2016, 07:15 AM
lsturbo32's Avatar
Default Re: Very weird noise coming from intake
post a video...hard to diagnose a sound without really hearing it or seeing the car
Old 02-11-2016, 12:18 AM
wunfstgsr's Avatar
well if the sounds gone with a diffrent intake then ditch the intake, you say its a ls intake but is a after market intake? and i doubt a intake will cause a loud noise you describe, might be a drive belt to axles, try diognosing it a lil more than just saying its a loud noise, have you removed the power steasring belt and AC belt to rule out those belts? does the sound get louder as the engine revs higher? thats would point to something internal or trans related.
Old 03-14-2016, 12:07 AM
Found out it was the Iav sensor. I would post a video if I knew how to just to show it was pretty loud.
DSBP1
18
07-07-2007 07:51 PM
aznxpyroboi
06-01-2007 08:21 PM
h-townteg
06-15-2006 10:57 AM
Puffwheat
02-13-2004 09:59 PM
Quick Reply: Very weird noise coming from intake
