bent valves???
Old Oct 24, 2002 | 11:15 AM
SoSoJeff's Avatar
Default bent valves???
how can you tell if you have bent valves? thanks
jeff
Old Oct 24, 2002 | 11:19 AM
94TealGSR's Avatar
Default Re: bent valves??? (SoSoJeff)
What makes you htink they're bent? When mine were bent, I took them to a machine shop and had them measure them... but I obviously had them out of the car and I'm guessing you don't.
Old Oct 24, 2002 | 11:46 AM
94teggyls's Avatar
Default Re: bent valves??? (94TealGSR)
if the valves r bent u can hear them like a rattle sound
Old Oct 24, 2002 | 12:04 PM
mickey513's Avatar
the car will idle like crap, lost of hp, you will hear the valves rattle/loud tapping
Old Oct 24, 2002 | 01:18 PM
irdprelude's Avatar
Default Re: bent valves??? (mickey513)
anyone have pics of bent valves?
Old Oct 24, 2002 | 01:33 PM
B00ST2nR's Avatar
Default Re: bent valves??? (irdprelude)
Your car would idle like crazy. Up and down, dying on you, and loss of noticeable performance.
Get a compression test done. If any of your valves are even slightly bent, the compression ratio will come out abnormal. If they come out perfectly, then it's not Bent Valves. It's probly another problem...
Old Oct 24, 2002 | 05:32 PM
SoSoJeff's Avatar
Default Re: bent valves??? (Skunk2nR)
ahhhh thanks for the help guys
Old Oct 24, 2002 | 08:21 PM
mod5's Avatar
if you have bent valve(s), you'll notice a slight ticking sound during idle and your compression will be low(depending on how bad the valves are bent).
Old Oct 24, 2002 | 08:30 PM
piatl7il77's Avatar
Default Re: bent valves??? (mod5)
yeah do a compression test.
Old Oct 24, 2002 | 08:53 PM
Mr. Softee's Avatar
Default Re: bent valves??? (piatl7il77)
depends on how bad you bend them. sometimes its barely noticable. sometimes the car wont even turn over. (my case). I not only bent valves, i broke some.
junkyard racer
Sep 7, 2008 04:41 PM
Baron55
Dec 24, 2005 08:02 AM
8400 rpm
Jul 28, 2002 08:57 AM
evo
Aug 24, 2001 12:56 PM
