VAFC problem...PLEASE HELP ASAP!!!
Old Feb 4, 2002 | 12:21 PM
Stunna BEN's Avatar
Don't call it a comeback
Default VAFC problem...PLEASE HELP ASAP!!!
Sup. After install of my VAFC when on the throttle after bout 50-60mph theres a problem. The engine light comes on, and the car will not go past 6500rpm. What could my problem be? Wiring or something in the VAFC?
Old Feb 4, 2002 | 12:36 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: VAFC problem...PLEASE HELP ASAP!!! (Big Carbon)
Do you have that throttle setting where the arrow is pointing upwards? Before I did that, I had the same problem. Also make sure the other settings are right....ya know, like 4 cylinder, as opposed to 6, etc.
Old Feb 4, 2002 | 12:38 PM
canuck-mx6's Avatar
vtec is getting disabled by the ECU. ensure that you have the VTM wire hooked up. If you changed the VTEC point from stock, you have to set the vtec unmatched settings, otherwise your ECU is using the wrong maps
Old Feb 4, 2002 | 04:52 PM
Stunna BEN's Avatar
Default Re: VAFC problem...PLEASE HELP ASAP!!! (canuck-mx6)
That helps alot! THanx
Old Feb 4, 2002 | 05:09 PM
alexboy's Avatar
Check your VTM wire it should be totally cut through not just spliced
Shakes
Feb 26, 2004 01:39 PM
COLORPROS
Feb 4, 2003 09:29 AM
Hybrid 350GT
Nov 11, 2002 10:24 AM
The Poopsmith
Aug 15, 2002 05:18 PM
