usual suspects?
Old Jul 10, 2005 | 08:17 AM
eymnewdc4's Avatar
Default usual suspects?
ok ..... here goes. we may have to add questions and things of the like later. my steering feels super sloppy. keep in mind the car is 10 years old. now its not bouncy, so im thinking it may not be shocks/struts just yet, but not ruling them out completely. what other suspension related parts should i look at and inspect in further detail? im more than willing to upgrade but at the same time, i cant afford to replace/upgrade things that dont need it just yet.
help me out HT, always have in the past.
Old Jul 10, 2005 | 08:19 AM
Magick211's Avatar
Default Re: usual suspects? (eymnewdc4)
Do you have play in the steering?
Old Jul 10, 2005 | 05:10 PM
eymnewdc4's Avatar
Default Re: usual suspects? (Magick211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have play in the steering?</TD></TR></TABLE>
yes, not rediculous amounts, but more than should be
Old Jul 11, 2005 | 05:11 AM
eymnewdc4's Avatar
up
Old Jul 11, 2005 | 06:52 AM
purplegsr's Avatar
take a look at the Inner and Outer tie rod ends and the front lower balljoints (where the steering knuckle meets the LCA). I assume you don't have any issues with the axle clicking? No torn cv boots?
Old Jul 11, 2005 | 06:59 AM
eymnewdc4's Avatar
Default Re: usual suspects? (purplegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">take a look at the Inner and Outer tie rod ends and the front lower balljoints (where the steering knuckle meets the LCA). I assume you don't have any issues with the axle clicking? No torn cv boots?</TD></TR></TABLE>
no clicking. are the tie-rod ends best replaced with OEM parts? (if thats what it is)
Old Jul 11, 2005 | 07:03 AM
purplegsr's Avatar
yeah, oem tie rod ends do the job well, I just got a set of outer tie rod ends for $80. They are easy to change. If the outer bushing looks really worn, you might consider replacing it to see if it helps. If the bushing is still nice and new looking, and when you squeeze it it feels soft and bounces back, it's still good. If it's cracking and grease is oozing out, it's time for a change.
Old Jul 11, 2005 | 07:22 AM
eymnewdc4's Avatar
ive not had a chance to get a GOOD look at them, but id imaging 10 year old bushing may have a good chance of being bad by now.
alright ... ill start there. any other suggestions?
Old Jul 11, 2005 | 11:42 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
This is an easy fix. Go with the Energy Suspension or Prothane suspension master kit. It sells for roughly $100-150 and it replaces your worn stock, rubber bushings with stiffer urethane bushings.
The master kit will replace all stock rubber bushings, and since yours are probably pretty worn out, you should look at it as a long term investment.
Quicker steering respose and crisp handling.
Old Jul 11, 2005 | 12:45 PM
internetautomart's Avatar
your tires may be getting old and the sidewall softening, that can also lead to an unresponsive feeling
Old Jul 11, 2005 | 05:18 PM
eymnewdc4's Avatar
Default Re: usual suspects? (carma_626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma_626 &raquo;</TD></TR><TR><TD CLASS="quote">This is an easy fix. Go with the Energy Suspension or Prothane suspension master kit. It sells for roughly $100-150 and it replaces your worn stock, rubber bushings with stiffer urethane bushings.
where would i get these? ive only seen kits for sway bars or whatever ... not the full out kit ...
Old Jul 11, 2005 | 05:20 PM
eymnewdc4's Avatar
Default Re: (internetautomart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by internetautomart &raquo;</TD></TR><TR><TD CLASS="quote">your tires may be getting old and the sidewall softening, that can also lead to an unresponsive feeling</TD></TR></TABLE>
ehh they are getting a little old. im saving up for a different size anyway. 195/50-15. my 205s are a little big/wide for me
Old Jul 12, 2005 | 04:48 PM
eymnewdc4's Avatar
checked it out today at work .. after 2 spark plugs broke off. dont ask.
all my suspension stuff is straight. one tech said that its most likely my rack and pinion.
hatcht9x
22
Jun 26, 2008 11:28 AM
krayjeegsr
Aug 18, 2006 11:06 PM
litterbox
Jan 17, 2005 10:33 PM
karlzhot
Nov 21, 2004 06:21 AM
jr_istheman
Jun 3, 2003 08:54 AM
