Urgent Electrical Question.
Old Sep 15, 2009 | 09:53 PM
thanh4o8's Avatar
Default Urgent Electrical Question.
Today i decided to take off my piping to get it done.
CEL went on.i left the cat on and it hung and started
scraping the ground. Drove home and on my way, my
speedo decides to stop working. then out of no where
my car dies when i hit the brakes at a red light. tried to
push start. had to feather the throttle to keep it alive.
couldnt drive AT ALL. friend came to jump start my car.
drove fine for a bit then it happended again. Drove home
and parked it.
Anyone have anything to say? I think the cat pulled on the
secondary o2 and messed up the harness or somthing.
threw two codes : 20-Electrical load detector
65 Secondary oxygen sensor heater
Old Sep 15, 2009 | 10:08 PM
seanbev24's Avatar
Default Re: Urgent Electrical Question.
If the secondary o2 sensor got yanked on 1 or more of the wires could have become shorted, which can cause all kinds of electrical problems.
Old Sep 15, 2009 | 10:22 PM
thanh4o8's Avatar
if it was shorted. what should i check ? fuses? relays?
Old Sep 15, 2009 | 11:10 PM
djviet2000's Avatar
should check all of it. it wouldnt hurt to try.
Old Sep 16, 2009 | 09:48 AM
seanbev24's Avatar
First find the short and repair it, then replace any blown fuses. Reset the ecu and see if the problems are solved.
Years ago I had a cherokee that had tons of wierd electrical problems. All it turned out to be was 2 shorted wires on the trailor hitch harness. I fixed the wires, replaced 2 fuses that kept blowing, and everything was perfect
Old Sep 16, 2009 | 10:47 AM
follie gatts's Avatar
you're lucky...you know exactly what the problem is. try a different sensor, or follow the wire on the harness it clips to. something had to rip and is shorting out now. sounds like an easy fix, don't forget to replace fuses and reset the ecu each time you test a fix.
Old Sep 16, 2009 | 07:54 PM
thanh4o8's Avatar
on an obd2 integra. where does the second sensor go? it runs through a hole of the chassy
Old Sep 16, 2009 | 08:30 PM
seanbev24's Avatar
It goes through a grommet in the floorboard, under the dash behind the center console area
Old Sep 16, 2009 | 09:46 PM
thanh4o8's Avatar
i tried looking for it but no luck. theres a brace blocking all the wires.
thanh4o8
Sep 17, 2009 07:47 PM
Fel_15
Feb 6, 2009 07:23 AM
b 1 6 e g
Feb 27, 2006 11:29 AM
Nero2007
11
Jul 28, 2004 04:22 PM
HYREV2NR
May 13, 2004 11:52 AM
